setting up shocky on AFPD?
OH
Hey guys I have been flying on afpd for about 3 months now and got pretty good at flying the 330s shocky with the help of the most common settings you guys use. I just got my first 330s shocky built a few weeks ago and it turns out that I learned to fly on afpd but it doesn't fly like mine and I am trying to see if anyone can help me set my plane up better on afpd and in real life. I have an axi 2208/34, jeti advanced 08 plus, blue bird rx, 3 hs-55 servos, 10x4.7 prop on a 7.4v 1200mah lipoly from etech at around 230g. I fly this outdoors so I wasn't afraid of a lil weight. my problem is CG I think and not enough throw in the servos. I am only getting around 20 degrees on elevator and ailerons and about 35 degrees on rudder. I cant get a good balanced hover with my real plane like I can on afpd. the thing I am confused about on afpd is prop wash and how to set the motor and battery to my set up. I have my CG on my real plane set to as close as I could get it to the center of the wings, around 80 mm from LE. from afpd that's 0 cm if I am not mistaken. if any of you guys have any tips or suggestions on what I should change on both please tell me, that would help me out a lot and I would greatly appreciate it thanks!
