motor sound
CA
RE: motor sound
If you change the model in the tmd, (1.8 or what ever to 1.6) the sounds should be there. If not then check the airplane folder for sounds files. If it has any put it in the sound folder in afp. If there still isn't anything there, just modify the sound text in the tmd to some airplane sound that you like.
Good luck,
Matt
Good luck,
Matt
