T-Rex for AFPD
My Feedback: (54)
FL
T-Rex for AFPD
Anyone have one...
How about other electric helis...
Can someone also post some tips on setting helis up. The stock setup is very sensitive and requires full throttle just to get off the ground.
Thanks.
Thanks.
FL
RE: T-Rex for AFPD
Ok, setting up your heli. first do you have a programable radio it would make it alot easier, but we'll do it through AFPD. First select what aircraft you want, and select edit aircraft. Select the main rotor, and then select the last little button on the bottom... the one for contrls. what i do it put the pitch inputs at there min and max to have ultimate control. Then Select the cyclic control and put it on 4.5. This is still senvitive enough to do mild aerobatics but dull enough to hover easily. If you have any other questions just ask and I'll do my best to help.
Chris
Chris
