Which 3D modelling software options for AFPD?
Hi
The tutorials I have used so far both use Metasequioa for building the 3D model, which is saved as a *.suf and then converted by the AFPD converter program.
Questions: is it possible to model directly in the format that AFPD used for its models (*.obj) and what is this format if it is not a specific AFPD format; if not, can I use any other modelling software, such as Blender, saving as e.g. a DXF, then importing and converting to .suf?
DS
DS
RE: Which 3D modelling software options for AFPD?
Hi,
the only prgram that can do this is [link=http://www.ac3d.org/]AC3D[/link], but you need the exporter from IPACS to export to .tgo and/or .obj(IPACS)
But the program is not free, about 70$.
Thanks Algenbrot. Is the exporter available from IPACS?
BTW - what is the difference between .tgo and .obj files?
DS
DS
Hi,
i think if you send an e-mail to [email protected] and ask for the exporter for AC3D you will get it.
The difference between .tgo and .obj
.obj
-larger file size
-takes longer to load
-ASCII Text
.tgo
-smaller
-faster to load
-encrypted
.obj
-larger file size
-ASCII Text
.tgo
-smaller
-faster to load
-encrypted
Thanks very much. I'll give AC3D a go and if I'm going to buy it, I'll email for the exporter.
DS
DS
CA
ORIGINAL: algenbrot
Hi,
Hi,
Regards,
Matt
