EasyFly2 add-ons
EasyFly2 add-ons
I just purchased the new Easyfly2, do you know if there are any "down-loadable" models available out there?
Or any way to convert AFPD or easyfly models into easyfly2?
Thanks, regards from the land of ice and fire [8D]
Moderator
My Feedback: (58)
RE: EasyFly2 add-ons
Hi einarak, as I understand it, there is a possibility of add-on models and sceneries for Easyfly2. However, since Easyfly2 is relatively new in the market, the timing of the add-on is uncertain for now. But do take a peep once in a while in the Easyfly2 website http://www.easyfly2.com/ for the latest updates and news.
My Feedback: (21)
just got my easyFLY2 and aint to bad so far just cant get the smoke to come on yet, i turned it on in the menu, but it aint doing nothing, cant wait til' some add ons are downloadable. nice sim for 99 Bucks. all i wanted was something to warm up my thumbs before flying and got more than i expected...thanks IkARUS.
Moderator
My Feedback: (58)
Hi Sigman, to enable your smoke:
1) Make sure you have assigned a Tx switch in the control menu
2) Calibrate the Tx switch - neutral (switch is in smoke off position) and max travel (smoke switch is in smoke on position)
3) In the flying view, under the graphics menu, enable smoke
Also, if you're using dual rates, calibrate the aircraft control surfaces with your Tx set at high rates. Let me know how this works out.
On a side note, the physics of the Easyfly2 is the same as in AFPD, but you can't edit the models. It's a good choice for what you want to do.
My Feedback: (21)
Thanks Rajul, that did the trick. [sm=thumbup.gif] there is a sound and music edit option, i can here all the engines running but there is no music or no way to upload music to the program. is there suppose to be a way to fly to music so i can practice routines ?
My Feedback: (21)
been trying to figure out how to hover the heli's inverted, i went into the menu and assigned autorotation to channel number 5 and when i flip the heli upsidedown i flip channel 5 and it seems like it wants to hover but i can move the throttle from idle to WOT and it doesnt do anything can someone help me figure out what im doing wrong? thanks.
Moderator
My Feedback: (58)
Sigman, you don't need the autorotation function for inverted flight. It is used to kill the engine for practising autos.
You will need a V-shaped throttle curve for inverted flight e.g. 100 75 50 75 100 on your Tx. Calibrate your throttle/collective stick with the neutral point at half-throttle position (50). In EF2, you can't set the pitch curve of the heli model
My Feedback: (21)
thanks rajul, this sim is the only place i've ever flown a heli,so i dont much about heli's and not alot more about planes, so thanks for editing your in depth explanation about how to hover a heli, it was all jibberish to me...lol! besides it sounds like i will need a better radio for that kind of flying. i have a JR XF631 , a basic 6 channel sport radio.
p.s. your avatar rocks! he looks entirely to happy !
Hi, is there anyway to set up easy fly so that you can switch between normal and idle up modes when flying helis. I find it annoying having the heli permanently in idle up.
