Problems with AFPD
Problems with AFPD
Hi, I am experiencing some problems with my AFPD simulator.
It has been running fine up till now, but for some reason the ailerons will not trim out properly, by this I mean I can calibrate them and its fine but when testing them on a model I put left in and the right aileron rises a little bit first then the left aileron goes up which is correct and the same happens for when I do this with right aileron.
This means during flight the ailerons can never be trimmed properly and doing a slow roll properly is impossible as the plane rolls right first for a left roll and then proceeds to roll left!
Can somebody please help!
Graham
Graham
RE: Problems with AFPD
I am using the game commander that comes with the simulator, and I experience it on all model but some more noticeable than others,
thanks
thanks
Moderator
My Feedback: (58)
Graham, looks like the pots in the game commander is faulty. You have two options i.e. to send it in for repair or replacement OR to use your own Tx, which I recommend as you get to use the Tx program mixes. You will need to get the usb slave cable and a suitable adapter for your Tx. In the UK, you will need to send in your GC to:
J Perkins Distribution Ltd
Northdown Business Park
Ashford Road
Lenham
Kent ME17 2DL
UK.
Telephone 0044 (0)1622 854 300
Email Servicing/Support [email protected]
Ashford Road
Lenham
Kent ME17 2DL
UK.
