TX setting all mixed up HELP!!!
GA
I just installed the program and I'm using a JR XF421 EX 5 Chan TX. This is the one that comes with the H9 P-51 PTS Trainer. I can't get any plane up in the air!!
What should the settings be when trying to calibrate an aircraft for the ailerons, elevators, throttle and rudder?
Hopefully someone here has had the same problem.
Moderator
My Feedback: (58)
RE: TX setting all mixed up HELP!!!
Abaco, I assume you have AFPD? Did you connect a JR adapter between the usb interface and your radio? Is your radio in PPM mode?
Additionally, do you have any addons (addon1 and/or starflight addon)? If you do, have you installed patch 1.9.7.11? If you do not have any addons, please install patch 1.8.0.25.
Channel assignment and calibration is covered in Chapter 10 of your manual. I would advise you to go through the manual first.
