AFDP Controller Interface Problem
My Feedback: (10)
I have a controller with a usb interface. Worked just fine. Now I have a newer computer. When I load and start the sim, I get the old "can't find the usb" window. I think a number of other people have had this problem. I have looked through the threads and haven't found (or haven't recognized) any thing I could use. Please help or point me in the right direction!
Frank
Frank
My Feedback: (10)
RE: AFDP Controller Interface Problem
I reloaded afds, downloaded the no addons patch, moved to a new and unused usb port but no joy. Previously, I used a real flight xmtr. Could this be the problem?
Moderator
My Feedback: (58)
Which version of AFPD do you have - the interface version, or the game commander version?
If you're using a G2/G3 controller, you will still have to plug in the AFPD usb interface or AFPD game commander into a free usb port. The G2/G3 controller should be configured as a joystick in controls.
Please look in the windows game controller settings (under control panel), if the usb interface shows up there?
My Feedback: (10)
I have version 1.8.0.21 upgraded with the patch. If this doesn't tell you the answer to the commander/controller,where should I look? The game controller icon acknowledges the installation of a "game controller" and the usb interface light is lit on the realflight xmiter. However, the calibration exercise shows the inputs are screwed up....pitch on the xmtr doesn't match rotation around the y axis, etc.
Frank
Frank
My Feedback: (10)
I pulled out the old G-2 and got it working almost immediately. Frankly, I'm not sure I know the difference between a game controller and a game commander. The only thing I have is the G-2 mock transmitter (Futaba) which calls itself a controller. BTW, thanks for your help. I'm sure we can get this solved.
Frank
Frank
