AFPD Unable to Locate USB Interface Cable
Hello,
I just purchased AFPD for my Futable 6EXAS. I am receiving a message "Unable to locate the USB Interface Cable". Windows can see the TX fine, shows up as an RC Joystick, when I move the Tx controls the Calibration settings move etc. in Windows... I have applied the most recent patch.
Can you assist me please? Here is the tm log. I am a newbie..Thanks!
tm: Library Version 4.2, Copyright (C) 1999-2005, IPACS
tm: http://www.ipacs.de
tmsystem: init random with 390197
tmsystem: cpu type=(nlogical=1) (nphysical=1) (hyper-threading disabled)
tmsystem: cpu=2527 Mhz
tmsystem: memory=(physical=1021MB, avail=487MB) (virtual=2047MB, avail=1663MB)
tmsystem: operating system=Microsoft Windows XP Version 5.1 Service Pack 2 (Build 2600) Service Pack: Service Pack 2 (Build 2600)
tmgl: loading font v2 texture/arial10.tmf=(256x256) (32x255) ok
tmgl: loading mouse texture/mouse.tmt=ok
tmprogram: AeroFly Professional Deluxe Version 1.8.0.25, Copyright © 1998-2006 IPACS
loading configfile config/main.mcf=ok
loading player configfile config/player1.mcf=ok
loading player configfile config/player2.mcf=ok
directsound: register sound sound/beep.wav=ok
directsound: register sound sound/balloon.wav=ok
directsound: register sound sound/crash.wav=ok
directsound: register sound sound/splash.wav=ok
directsound: register sound sound/glider.wav=ok
directsound: register sound sound/glider2.wav=ok
afdesign: init ok
tmgl: loading font v2 texture/menufont.tmf=(512x512) (32x255) ok
directinput: init=ok
tmsystem: current monitor frequency=60
init window=(window=800x600) (screen=1024x768) (16bpp) (60Hz) (window)
directsound: init=(speakerconfig=unknown) (certified) (cont.rate) (primary 16bit) (samplerates 100,192000) (33 hwbuffers) (0 hwbytes)
init pixelformat=ok
gl: vendor=ATI Technologies Inc., renderer=RADEON 9200 Series DDR x86/SSE2, version=1.3.1072 WinXP Release
gl: (viewport=2048x2048) (texturesize=2048) (stencil=8)
gl: extensions=GL_ARB_multitexture GL_EXT_texture_env_add GL_EXT_compiled_vertex_array GL_S3_s3tc GL_ARB_occlusion_query GL_ARB_point_parameters GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_transpose_matrix GL_ARB_vertex_blend GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_window_pos GL_ATI_element_array GL_ATI_envmap_bumpmap GL_ATI_fragment_shader GL_ATI_map_object_buffer GL_ATI_texture_env_combine3 GL_ATI_texture_mirror_once GL_ATI_vertex_array_object GL_ATI_vertex_attrib_array_object GL_ATI_vertex_streams GL_ATIX_texture_env_combine3 GL_ATIX_texture_env_route GL_ATIX_vertex_shader_output_point_size GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_stencil_wrap GL_EXT_texgen_reflection GL_EXT_texture3D GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_rectangle GL_EXT_vertex_array GL_EXT_vertex_shader GL_HP_occlusion_test GL_NV_blend_square GL_NV_occlusion_query GL_NV_texgen_reflection GL_SGI_color_matrix GL_SGIS_generate_mipmap GL_SGIS_multitexture GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_SUN_multi_draw_arrays GL_WIN_swap_hint WGL_EXT_extensions_string WGL_EXT_swap_control
wgl: extensions=WGL_ARB_extensions_string WGL_ARB_make_current_read WGL_ARB_pbuffer WGL_ARB_pixel_format WGL_ARB_render_texture WGL_EXT_extensions_string WGL_EXT_swap_control
gl: extensions=(lockarrays) (multitexture) (pointparameter) (vertexbufferobject) (separate color) (anisotropic filter of 16.00) (compressed texture) (cubemaps)
wgl: extensions=(wglpixelformat) (wglrendertexture) (swapcontrol)
tmsystem: fullscreen modes=(640x480x16x60) (rj-640x480x16x72) (rj-640x480x16x75) (rj-640x480x16x85) (rj-640x480x16x90) (rj-640x480x16x100) (rj-640x480x16x120) (rj-640x480x16x160) (rj-640x480x16x200) (rj-640x480x32x72) (rj-640x480x32x75) (rj-640x480x32x85) (rj-640x480x32x90) (rj-640x480x32x100) (rj-640x480x32x120) (rj-640x480x32x160) (rj-640x480x32x200) (rj-720x480x16x60) (rj-720x480x16x75) (rj-720x480x16x85) (rj-720x480x32x60) (rj-720x480x32x75) (rj-720x480x32x85) (rj-720x576x16x59) (rj-720x576x16x60) (rj-720x576x16x75) (rj-720x576x16x85) (rj-720x576x16x100) (rj-720x576x32x59) (rj-720x576x32x60) (rj-720x576x32x75) (rj-720x576x32x85) (rj-720x576x32x100) (800x600x16x47) (800x600x16x56) (rj-800x600x16x70) (rj-800x600x16x72) (rj-800x600x16x75) (rj-800x600x16x85) (rj-800x600x16x90) (rj-800x600x16x100) (rj-800x600x16x120) (rj-800x600x16x160) (rj-800x600x16x200) (rj-800x600x32x70) (rj-800x600x32x72) (rj-800x600x32x75) (rj-800x600x32x85) (rj-800x600x32x90) (rj-800x600x32x100) (rj-800x600x32x120) (rj-800x600x32x160) (rj-800x600x32x200) (rj-848x480x16x60) (rj-848x480x16x75) (rj-848x480x16x85) (rj-848x480x32x60) (rj-848x480x32x75) (rj-848x480x32x85) (1024x768x16x43) (1024x768x16x60) (rj-1024x768x16x70) (rj-1024x768x16x72) (rj-1024x768x16x75) (rj-1024x768x16x85) (rj-1024x768x16x90) (rj-1024x768x16x100) (rj-1024x768x16x120) (rj-1024x768x16x150) (rj-1024x768x16x160) (rj-1024x768x16x200) (rj-1024x768x32x70) (rj-1024x768x32x72) (rj-1024x768x32x75) (rj-1024x768x32x85) (rj-1024x768x32x90) (rj-1024x768x32x100) (rj-1024x768x32x120) (rj-1024x768x32x150) (rj-1024x768x32x160) (rj-1024x768x32x200) (1152x864x16x43) (1152x864x16x60) (rj-1152x864x16x70) (rj-1152x864x16x75) (rj-1152x864x16x85) (rj-1152x864x16x100) (rj-1152x864x32x70) (rj-1152x864x32x75) (rj-1152x864x32x85) (rj-1152x864x32x100) (1280x720x16x60) (rj-1280x720x16x75) (rj-1280x720x16x85) (rj-1280x720x32x75) (rj-1280x720x32x85) (1280x768x16x60) (rj-1280x768x16x75) (rj-1280x768x16x85) (rj-1280x768x32x75) (rj-1280x768x32x85) (1280x960x16x60) (rj-1280x960x16x70) (rj-1280x960x16x72) (rj-1280x960x16x75) (rj-1280x960x16x85) (rj-1280x960x32x70) (rj-1280x960x32x72) (rj-1280x960x32x75) (rj-1280x960x32x85) (1280x1024x16x43) (1280x1024x16x60) (rj-1280x1024x16x70) (rj-1280x1024x16x75) (rj-1280x1024x16x85) (rj-1280x1024x16x90) (rj-1280x1024x16x100) (rj-1280x1024x16x120) (rj-1280x1024x16x160) (rj-1280x1024x16x180) (rj-1280x1024x32x70) (rj-1280x1024x32x75) (rj-1280x1024x32x85) (rj-1280x1024x32x90) (rj-1280x1024x32x100) (rj-1280x1024x32x120) (rj-1280x1024x32x160) (rj-1280x1024x32x180) (1360x768x16x60) (rj-1360x768x16x75) (rj-1360x768x16x85) (rj-1360x768x32x75) (rj-1360x768x32x85) (rj-1360x1024x16x60) (rj-1360x1024x16x75) (rj-1360x1024x16x85) (rj-1360x1024x32x60) (rj-1360x1024x32x75) (rj-1360x1024x32x85) (1600x1200x16x60) (rj-1600x1200x16x70) (rj-1600x1200x16x75) (rj-1600x1200x16x85) (rj-1600x1200x16x100) (rj-1600x1200x16x120) (rj-1600x1200x32x70) (rj-1600x1200x32x75) (rj-1600x1200x32x85) (rj-1600x1200x32x100) (rj-1600x1200x32x120) (rj-1792x1344x16x60) (rj-1792x1344x16x72) (rj-1792x1344x16x75) (rj-1792x1344x16x85) (rj-1792x1344x16x90) (rj-1792x1344x16x100) (rj-1792x1344x32x60) (rj-1792x1344x32x72) (rj-1792x1344x32x75) (rj-1792x1344x32x85) (rj-1792x1344x32x90) (rj-1792x1344x32x100) (rj-1800x1440x16x60) (rj-1800x1440x16x70) (rj-1800x1440x16x72) (rj-1800x1440x16x75) (rj-1800x1440x16x85) (rj-1800x1440x16x90) (rj-1800x1440x16x100) (rj-1800x1440x32x60) (rj-1800x1440x32x70) (rj-1800x1440x32x72) (rj-1800x1440x32x75) (rj-1800x1440x32x85) (rj-1800x1440x32x90) (rj-1800x1440x32x100) (rj-1856x1392x16x60) (rj-1856x1392x16x72) (rj-1856x1392x16x75) (rj-1856x1392x16x85) (rj-1856x1392x16x90) (rj-1856x1392x16x100) (rj-1856x1392x32x60) (rj-1856x1392x32x72) (rj-1856x1392x32x75) (rj-1856x1392x32x85) (rj-1856x1392x32x90) (rj-1856x1392x32x100) (1920x1080x16x30) (1920x1080x16x60) (rj-1920x1080x16x75) (rj-1920x1080x16x85) (rj-1920x1080x16x100) (rj-1920x1080x16x120) (rj-1920x1080x32x75) (rj-1920x1080x32x85) (rj-1920x1080x32x100) (rj-1920x1080x32x120) (1920x1200x16x60) (rj-1920x1200x16x75) (rj-1920x1200x16x85) (rj-1920x1200x16x100) (rj-1920x1200x32x75) (rj-1920x1200x32x85) (rj-1920x1200x32x100) (1920x1440x16x60) (rj-1920x1440x16x75) (rj-1920x1440x16x85) (rj-1920x1440x16x90) (rj-1920x1440x32x75) (rj-1920x1440x32x85) (rj-1920x1440x32x90) (rj-2048x1536x16x60) (rj-2048x1536x16x66) (rj-2048x1536x16x70) (rj-2048x1536x16x75) (rj-2048x1536x16x85) (rj-2048x1536x32x60) (rj-2048x1536x32x66) (rj-2048x1536x32x70) (rj-2048x1536x32x75) (rj-2048x1536x32x85)
directinput: searching joysticks=(0: 7 axes, 6 buttons)
tminput: searching for input devices...(1)
tmsystem: searching usb interface (0) 0=unable to open interface device
tmsystem: searching usb interface (1) 0=unable to open interface device
tmsystem: searching usb interface (0) 0=unable to open joystick device
tminput: 0 devices found
tminput: searching for input devices...(2)
tmgl: loading font v2 texture/arial20b.tmf=(256x256) (32x255) ok
sim: loading scenery scenery/winzeln.geo...
sim: 1 objects 0 dynobjects
sim: start position 1 (not for helicopter)
sim: start position 2 (not for helicopter)
sim: start position 3 (not for helicopter)
sim: start position 4 (not for airplanes)
sim: load texture grid 5x5 (compress=1) named winzeln/winzeln=(5x5) (24x13) (72.00 36.00) (3.00 3.00)
sim: sphere params=-1.5000 0.0000 -0.7000
sim: loading ground object scenery/winzeln/winzeln.obj=ok
sim: loading time=110589 mus
tmcollision: 1604 triangles using 109072 bytes
tmcollision: omin=(-5000.0,-5000.0,-2.1) omax=(5000.0,5000.0,59.6)
tmcollision: octmin=(400.0,400.0,400.0)
tmcollision: otnodes=37 otdepth=11
tmcollision: otnmaxareas=838 otnavgareas=48 otnminsize=(312.500,312.500,61.746)
tmcollision: otareas=1801 mem=100856
tmcollision: otclppl=5604 mem=179328
tmcollision: 37 octrees, using 9620 bytes
tmcollision: total mem=398876 bytes
tmcollision: time=18844mus
tmcolldynamic: no dynamic objects or triangles
sim: loading aircraft 1 christeneagle...
tmdairfoil: loading naca0015 ok
tmdairfoil: loading flat ok
tmdairfoil: loading naca0009 ok
directsound: register sound sound/g15-3000.wav=ok
directsound: register sound sound/g15-5000.wav=ok
directsound: register sound sound/g15-10000.wav=ok
generating shadow christeneagleshadow0=radius=2.13 bbmin=(-1.28 -1.28 -0.46) bbmax=(1.28 1.28 0.27)
sim: creating blurr=Propeller
tmmusic: off
directinput: shutting down joystick 0
directsound: shutdown
directinput: shutdown
saving configfile config/main.mcf=ok
saving player configfile config/player1.mcf=ok
tmsystem: 0 memory blocks:
tmsystem: shutdown, 0 memory blocks left using 0 bytes
afdesign: init ok
init pixelformat=ok
tmmusic: off
Moderator
My Feedback: (58)
RE: AFPD Unable to Locate USB Interface Cable
Hi mleuba, did you install any add-on disk as well?
plug in the usb interface into a usb port. Then go to Start->Control panel->Game controllers. Do you see "Ikarus Interface" shown in the window? If not, try other usb ports and check game controller again. Please do not connect through a usb hub. Let me know.
Hi Rajul,
I did not install the add-on disk, should I? I will now...
The USB interface is plugged into a native port on my Dell B110. The Game Controller shows "RC Joystick". The device is being seen by Windows, when I move the Tx controls, the joystick properties move up/down/around so Windows sees the transmitter, but AFPD does not....
Here is my tm log. Thanks a lot for your Help ! Mark.
tmsystem: init random with 275391251
tmsystem: memory=(physical=1021MB, avail=460MB) (virtual=2047MB, avail=1739MB)
tmprogram: AeroFly Professional Deluxe Version 1.9.1.3, Copyright © 1998-2005 IPACS
afdesign: init ok
init pixelformat=ok
sim: loading time=2097044 mus
tmcollision: time=23115mus
tmmusic: off
afdesign: init ok
init pixelformat=ok
tmmusic: off
Moderator
My Feedback: (58)
If you install any add-on, you will need to apply patch 1.9.7.11. The sequence of installation should be addon, then the patch.
I would like you to do the following test. Please plug in the usb interface into other native usb ports and see if AFPD can detect it? Do you have another PC to test on? On the other PC, without installing AFPD, please plug in the usb interface into a usb port and see what appears in game controllers?
Could you PM or email me a picture of the usb interface you have? Where did you purchase your AFPD from?
Hi Rajul,
Will apply the patch, thanks.
Just took the TX and cable to my laptop and plugged in. Same exact result. The Windows Game Controller shows "RC Joystick". It acts the same, meaning I can select the Test mode in Windows and move the Tx sticks around and see them move in the windows test box...can also do the calibration wizard etc. The Tx connected via cable works same on my desktop and my laptop (which does not have AFPD installed)...
I just bought the product from another Aeromodeler, they bought it from Ikarus direct, serial number 3021004.
Here are pictures...
Thanks again for your quick replies. I appreciate your help.
Mark
Mark
Moderator
My Feedback: (58)
mleuba, I am afraid that what you have is not the original AFPD interface. That explains why it cannot work with AFPD. The original AFPD interface has a built-in security key. I suggest that you return it to the seller for a refund. The original AFPD usb interface and game commander looks like what you can see here http://www.ikarus-modellbau.de/onlin...alist&cnid=302 If you have your own computer radio, I suggest that you get the interface version.
Thank you Mike,
This is very concerning, may I contact you off-line please? My email is [email protected].
Thanks.
Thanks.
