AFP crashing on WinXP, computer restarting
I've had AeroFly Pro (not deluxe) running on desktop machine with no problems but now need to move to a laptop. Installed the main program followed by update disc then the latest patch. It runs for a something between 2 and 10 minutes then computer shuts down with no warning. When restarting I get a message that the system has recovered from a serious error with a prompt to send a log of the error to Microsoft.
The machine is a Lenovo 3000 C100 0761 1.86Ghz Pentium mobile with 1Gb RAM running Windows XP home.
I updated video driver (Intel mobile 915GM/GMS, 910GL) but no change.
Tried running in Windows 98 compatibility mode, still the same.
After doing a bit of searching on the internet I installed Microsoft Debugging Tools and used debugwiz to analyze the error logs created when the error occurs. This indicated one possible cause as file ALCXWDM.SYS. Further searching revealed that this was connected with the Realtek AC'97 audio driver so got the latest update for that and installed. This also made no difference so looks like it is not the culprit.
I've uninstalled and reinstalled several times making sure that installation and patches are loaded in the correct order but am now getting to the point where frustration has led me to seek advice from this forum.
I have included below the contents of tm.log file .
Any help or suggestions would be much appreciated.
kirkyboy
tm: Library Version 4.0, Copyright (C) 1999-2003, IPACS
tm: http://www.ipacs.de
tmsystem: init random with 140775386
tmsystem: cpu type=(nlogical=1) (nphysical=1) (no hyper-threading)
tmsystem: cpu=1729 Mhz
tmsystem: memory=(physical=1015MB, avail=446MB) (virtual=2047MB, avail=1769MB)
tmsystem: operating system=Microsoft Windows 98 Version 4.10 (Build 2222)
afdesign: init ok
tmgl: loading font v2 texture/serif10.tmf=(256x256) (32x255) ok
tmgl: loading mouse texture/mouse.tmt=ok
tmprogram: AeroFly Professional Version 1.6.8.6, Copyright © 1998-2004 IPACS
loading configfile config/main.mcf=ok
loading player configfile config/player1.mcf=ok
loading player configfile config/player2.mcf=ok
directsound: register sound sound/beep.wav=ok
directsound: register sound sound/balloon.wav=ok
directsound: register sound sound/crash.wav=ok
directsound: register sound sound/splash.wav=ok
directsound: register sound sound/glider.wav=ok
directsound: register sound sound/glider2.wav=ok
directinput: init=ok
tmsystem: current monitor frequency=60
init window=(window=1024x768) (screen=1024x768) (32bpp) (60Hz) (fullscreen)
directsound: init=(speakerconfig=unknown) (certified) (cont.rate) (primary 16bit) (samplerates 8000,192000) (26 hwbuffers) (0 hwbytes)
init pixelformat=ok
gl: vendor=Intel, renderer=Intel 915GM, version=1.4.0 - Build 7.14.10.4764
gl: (viewport=2048x2048) (texturesize=2048) (stencil=8)
gl: extensions=GL_ARB_depth_texture GL_ARB_fragment_program GL_ARB_multitexture GL_ARB_point_parameters GL_ARB_shadow GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_env_crossbar GL_ARB_transpose_matrix GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_EXT_cull_vertex GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_packed_pixels GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture_compression_s3tc GL_EXT_texture_env_add GL_EXT_texture_env_combine GL_EXT_texture_filter_anisotropic GL_EXT_texture3D GL_3DFX_texture_compression_FXT1 GL_IBM_texture_mirrored_repeat GL_NV_blend_square GL_NV_texgen_reflection GL_SGIS_generate_mipmap GL_WIN_swap_hint
wgl: extensions=WGL_ARB_buffer_region WGL_ARB_extensions_string WGL_ARB_make_current_read WGL_ARB_pixel_format WGL_ARB_pbuffer WGL_EXT_swap_control
gl: extensions=(lockarrays) (multitexture) (vertexbufferobject) (separate color) (anisotropic filter of 4.00)
wgl: extensions=(wglpixelformat) (swapcontrol)
gl: reducing max texture size from 2048 to 512
tmsystem: fullscreen modes=(640x480x16x0) (rj-768x1024x16x0) (800x600x16x0) (1024x768x16x0) (rj-768x1024x32x0)
directinput: searching joystick=none
tmgl: loading font v2 texture/arial8b.tmf=(256x256) (32x255) ok
tmgl: loading font v2 texture/arial20b.tmf=(256x256) (32x255) ok
sim: loading scenery scenery/forestlake.geo...
sim: 2 objects 0 dynobjects
sim: start position 1
sim: start position 2
sim: start position 3
sim: ballons=10 (80.00,128.00,4.00) (105.00,152.00,8.00)
sim: dragrace=(100.00,180.00)
sim: spotarea=(20.00,14.00)
sim: pylon 1=(-40.00,140.00,-1.00)
sim: pylon 2=(110.00,125.00,-1.00)
sim: pylon 3=(110.00,155.00,-1.00)
sim: loading ground scenery/forestlake/forestlakef.obj
sim: loading object scenery/forestlake/forestlakeg.obj=ok
sim: loading object scenery/forestlake/forestlakeo.obj=ok
sim: 389 transparent geometries 388 billboards
sim: loading time=6056211 mus
tmcollision: 4223 triangles using 185812 bytes
tmcollision: 388 billboards
tmcollision: omin=(-7819.9,-8338.1,-0.0) omax=(8016.8,8285.5,471.0)
tmcollision: octmin=(20.0,20.0,20.0)
tmcollision: otnodes=2297 otdepth=26
tmcollision: otnmaxareas=79 otnavgareas=4 otnminsize=(15.466,16.234,14.718)
tmcollision: otareas=9990 mem=559440
tmcollision: otclppl=36517 mem=1168544
tmcollision: 2297 octrees, using 597220 bytes
tmcollision: total mem=2511016 bytes
tmcollision: time=277785mus
tmcolldynamic: no dynamic objects or triangles
tmgl: failed to load texture texture/water2.tmt
tmgl: failed to load texture texture/water1.tmt
sim: loading aircraft 1 f16tb...
tmdairfoil: loading naca64a204 ok
tmdairfoil: loading flat ok
directsound: register sound sound/f16.wav=ok
generating shadow f16tbshadow0=(generating fast shadow map)radius=3.13 bbmin=(-1.73 -1.73 -0.36) bbmax=(1.73 1.73 0.66)
tmmusic: play single song 0
tminput: searching for input devices...
tminput: checking for transmitter on comport 1=createfile failed
tminput: checking for transmitter on comport 2=createfile failed
tminput: checking for transmitter on comport 3=(receiving) none
tminput: closing comport
tminput: checking for transmitter on comport 4=createfile failed
tminput: checking for transmitter on comport 5=createfile failed
tminput: checking for transmitter on comport 6=createfile failed
tminput: checking for transmitter on comport 7=createfile failed
tminput: checking for transmitter on comport 8=createfile failed
tminput: 0 devices found
tminput: checking for joystick=fail
tminput: checking for transmitter on comport 2=found, 7 channels, t=256474
tminput: 1 devices found
loading input device calibration config/radio0.tmc=ok
directsound: deleting sound sound/f16.wav=ok
tmdairfoil: loading naca0015 ok
directsound: register sound sound/g15-3000.wav=ok
directsound: register sound sound/g15-5000.wav=ok
directsound: register sound sound/g15-10000.wav=ok
generating shadow cap232brshadow0=(generating fast shadow map)radius=3.00 bbmin=(-1.87 -1.87 -0.49) bbmax=(1.87 1.87 0.45)
sim: creating blurr=Propeller
directsound: loading sound 1 sound/beep.wav=(in hardware) cpu=0
directsound: loading sound 2 sound/balloon.wav=(in hardware) cpu=0
directsound: loading sound 3 sound/crash.wav=(in hardware) cpu=0
directsound: loading sound 4 sound/splash.wav=(in hardware) cpu=0
directsound: loading sound 5 sound/glider.wav=fail
directsound: loading sound 6 sound/glider2.wav=fail
directsound: loading sound 7 sound/g15-3000.wav=(in hardware) cpu=0
directsound: loading sound 8 sound/g15-5000.wav=(in hardware) cpu=0
directsound: loading sound 9 sound/g15-10000.wav=(in hardware) cpu=0
sim: switching to simulation mode...
tmdynamics: simulation started
sim: aircraft=(-50.00,72.00,1.17), viewer=(-53.00,72.00,1.67)
sim: 4144 memory blocks using 36395635 bytes
saving configfile config/main.mcf=ok
saving player configfile config/player1.mcf=ok
tmdynamics: simulation stopped
directsound: shutdown
init pixelformat=ok
sim: aircraft=(-50.00,72.00,1.17), viewer=(-41.00,80.00,2.97)
directsound: deleting sound sound/g15-10000.wav=ok
directsound: deleting sound sound/g15-5000.wav=ok
directsound: deleting sound sound/g15-3000.wav=ok
generating shadow su31shadow0=(generating fast shadow map)radius=2.46 bbmin=(-1.44 -1.44 -0.41) bbmax=(1.44 1.44 0.37)
directsound: loading sound 1 sound/beep.wav=already loaded
directsound: loading sound 2 sound/balloon.wav=already loaded
directsound: loading sound 3 sound/crash.wav=already loaded
directsound: loading sound 4 sound/splash.wav=already loaded
sim: aircraft=(-50.00,72.00,1.09), viewer=(-41.00,80.00,2.89)
sim: 4157 memory blocks using 39895406 bytes
kirkyboy
afdesign: init ok
init pixelformat=ok
init pixelformat=ok
Moderator
My Feedback: (58)
RE: AFP crashing on WinXP, computer restarting
Hi Kirky, your video card is not openGL compatible and will not work with AFP. You will need at least a 32MB openGL 3D video card such as the ones listed here http://www.aerofly.com/www/requirements.html Does your laptop have a built-in 9-pin serial port?
Why not consider upgrading your AFP to AFPD and enjoy improved physics, photorealistic sceneries, and a host of other features? http://www.ikarus-modellbau.de/onlin...43d22.84275286
Thanks for your quick reply.
In answer to your question my laptop does not have a built in serial port, I am using a USB to RS232 adapter.
The link to system requirements is for AFPD but I assume the same applies to the non deluxe version.
As I am using this on a laptop it is not possible to drop in another video card so guess I am not going to be able to use Aerofly if the video is not compatible. Also if Deluxe also needs a different video card then upgrading is not an option either.
kirkyboy[]
kirkyboy[]
