Trouble calibrating AFP on VISTA
NJ
Hi,
I need help calibrating AFPD on Vista Home Premium DELL Inspiron 1525 laptop. The problem has been discussed by others before but a definitive cause seems elusive. Symptom: When calibrating neutral position, red bars jump from side to side spastically. So AFPD cannot find control centers and plane will not fly. This is a new install.
- AFPD works FINE using the same cable/tx (Skysport w/out RF) on my DELL XP desktop - so I conclude the cable is OK.
- Product is AFPD 1.8.0.17 straight off install disk (no add ons, etc.).
- Laptop has 2 Ghz w/4Gb RAM. Display controller is Mobile Intel 965 express chipset family with latest driver
- I indicated to install directx 9 if necessary.
I tried applying the recommended AFPD patch 1.08.025 but error message indicated installer would not replace one file (I didn't write down which one).
I checked the game controller and confirmed channels operate smoothly and proportionately.
Any ideas?
Thanks.
Any ideas?
Thanks.
Moderator
My Feedback: (58)
RE: Trouble calibrating AFP on VISTA
Hi Seth, pls post your full tm.log file which you can find in the following directory
C:\Program Files\IPACS\AeroFly Professional Deluxe
You may open the file with a text editor like word or notepad. Just copy and paste the entire content into your post.
NJ
Hi Mike,
Thanks for following up. I really appreciate the help. My tm file is empty. 0 bytes. Hope that's a good thing?
Moderator
My Feedback: (58)
Hi Seth,
-Tell me exactly what kind of 3D card you have, and any other hardware installed, sound card etc.
-Which operating system are you using, 32bit or 64bit Vista?
-Tell me exactly what drivers you installed for the 3D card.
NJ
Well further research indicates the DELL Inspiron 1525 (2 ghz Intel Core 2 Duo CPU "Centrino") does not
have provision for a discrete graphics card. Curious though, the graphics performance of AFPD is great (until
the plane crashes). Regardless something tells me you're going to say this doesn't meet
AFPD minimum requirements.
Anyway to answer your question: 32 bit Windows Vista Home Premium
Intel (R) High Def Audio HDMI Intel Driver 3/26/2007 6.10.0.2025
Sigma Tel High Def Audio CODEC 9/13/2007 6.10.0.5614
Mobile Intel (R) 965 Express Chipset Family, PCI BUS, Intel driver 4/13/2007 7.14.10.1253
Moderator
My Feedback: (58)
Hi Seth, you will need an openGL compatible 3d graphics card listed in the requirements page here http://www.aerofly.com/www/requirements.html If you're using an on-board graphics processor, it will not work with AFPD.
