AFPD RUNNING SLOW ON HIGH FPS
Hi, guys,
I need your help.
When I installed My AFPD, a few months ago, it was running fine.
However, now, it is running like it was on slow motion, although my FPS is always around 90. My simulation speed is set to 120% and my version is the latest.
To reduce the slow motion (but not end it) I have to set the sim speed to 200%.
Any ideas on what´s going on?
Thanks!
Flavio
I need your help.
Thanks!
Flavio
Moderator
My Feedback: (58)
RE: AFPD RUNNING SLOW ON HIGH FPS
Hi flavio, there are a few things you could check as follows:
1) Make sure that your video card hardware acceleration is at 100%
2) Under graphics options, disable v-sync
3) You could have programs running in the background, disable all of them
4) You could have spywares and viruses, so pls scan your pc for viruses and run applications like Adaware and Spybot
Mike,
I did all that and the results are the same...
Do you think reinstalling could be a good idea, since it previously worked fine? Maybe installing on some other computer?
Flavio
Flavio
Moderator
My Feedback: (58)
Hi Flavio, yes you could try that. But before that, try updating your video card driver. Pls follow the uninstallation instruction given at the bottom of this page http://www.aerofly.com/www/downloads.html
Mike,
Thank you!!!
You were right! I updated the drivers and... Bingo! It´s all working fine now!
Flavio
Thank you!!!
Flavio
