Adjusting CG
Adjusting CG
Hi
I am trying to adjust the CG on the AFPD. When I get to the menu I am presented with three numbers. Can anyone tell me what the numbers are and which one I need to adjust to move the CG rearwards?
Mike
Mike
Moderator
My Feedback: (58)
RE: Adjusting CG
In the CG editor there are 3 boxes with values when you access the fuse area.
The three values in the cg editor are the cg position with respect to an arbitary reference point. The first value moves the cg forward (positive values) and backwards (negative values), the second to the left (+) and right (-) and the third value up(+) and down (-).
RE: Adjusting CG
Hi
Tried it last night. It would let me reduce the number to zero but wont let me put in a negative number( ie move the CG further back). Do I have a problem or will the software not allow negative numbers?
Mike
Mike
