upgrade path of AFPD
ME
Bought a new computer with Win 7 (prerelease version) and installed my AFPD version 1.8.0.17 and it worked fine. Patched to 1.8.0.25 and that worked. Then tried to go to 1.11.07.21 and now it won't run. Tried the "compatibility" procedure for Win 7 but no joy.
Did I miss a step here or is 1.8.0.17 as far as I can go?
Thanks in advance,
Bob
Thanks in advance,
Bob
Moderator
My Feedback: (58)
RE: upgrade path of AFPD
Hi Bob, could you tell me what was the error code and message? Please also provide the following information:
1) Tell me exactly what kind of hardware you have, especially 3D graphics card, CPU, and any other hardware installed, sound card etc.
2) What is the RAM size?
3) Which operating system are you using, Win7 32 bit or 64 bit?
4) Tell me exactly what drivers you installed for the 3D graphics card.
5) Which addons do you have?
6) What is the version number printed on your main AFPD disk?
7) How did you install the main disk, addons, and patch (which version?), and what was the sequence of installation?
8) Post the tm.log file which you can find in the following directory
C:\Program Files\IPACS\AeroFly Professional Deluxe
You may open the file with a text editor like word or notepad. Just copy and paste the entire content into your post.
ME
Thanks for the reply Mike. Here is what I know: (or think I know)
it is an NVIDA graphics card with version 7.2 driver(s). I can't find the paper that has the model number on it but it wasn't an inexpensive card(!) CPU is Intel, core 2 quad. C: is set up in a RAID 0 config.
4 GB
64
The latest, machine is only three weeks old, 7.2 it says on the disk.
I have no AFPD addons, just the original disk.
The number that showed up on the screen with the first install was 1.8.0.17. (It is also on the disk) The number on the original box #3021001
Main disk loaded fine, I flew for a week or two with no problems.
the patch 1.8.0.25 went on fine. I rebooted and tried the upgrade below, would not work. Then I tried installing it with "compatibility" turned on and Admin privileges checked. It said it installed but when I try to run it I get : "AeroFKt Professional Deluxe main executable has stopped working."
Below that these problem details were listed:
Problem signature:
Problem Event Name: BEX
Application Name: afprod.exe
Application Version: 1.11.7.21
Application Timestamp: 48a53dab
Fault Module Name: afprod.exe
Fault Module Version: 1.11.7.21
Fault Module Timestamp: 48a53dab
Exception Offset: 0028315e
Exception Code: c000000d
Exception Data: 00000000
OS Version: 6.1.7137.2.0.0.256.1
Locale ID: 1033
Additional Information 1: c604
Additional Information 2: c60453c9d02c65afd40d4c753aab2a53
Additional Information 3: 6656
Additional Information 4: 6656f920168f8003d5deddcdb091ad33
Read our privacy statement online:
http://go.microsoft.com/fwlink/?link...8&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
It was not in that directory but under users. File structure seems to be different in Win 7
tm: Library Version 4.2, Copyright (C) 1999-2005, IPACS
tm: http://www.ipacs.de
tmsystem: init random with 251467
tmsystem: cpu type=(nlogical=1) (nphysical=4) (no hyper-threading)
tmsystem: cpu=2666 Mhz
tmsystem: memory=(physical=4094MB, avail=2670MB) (virtual=2047MB, avail=1758MB)
tmsystem: operating system=Version 6.1 (Build 7137)
tmgl: loading font v2 texture/arial10.tmf=(256x256) (32x255) ok
tmgl: loading mouse texture/mouse.tmt=ok
tmprogram: AeroFly Professional Deluxe Version 1.8.0.25, Copyright © 1998-2006 IPACS
loading configfile config/main.mcf=ok
loading player configfile config/player1.mcf=ok
loading player configfile config/player2.mcf=ok
directsound: register sound sound/beep.wav=ok
directsound: register sound sound/balloon.wav=ok
directsound: register sound sound/crash.wav=ok
directsound: register sound sound/splash.wav=ok
directsound: register sound sound/glider.wav=ok
directsound: register sound sound/glider2.wav=ok
afdesign: init ok
tmgl: loading font v2 texture/menufont.tmf=(512x512) (32x255) ok
directinput: init=ok
tmsystem: current monitor frequency=59
init window=(window=800x600) (screen=1920x1080) (32bpp) (59Hz) (window)
directsound: init=(speakerconfig=unknown) (cont.rate) (primary 16bit) (samplerates 100,200000) (1 hwbuffers) (0 hwbytes)
init pixelformat=ok
gl: vendor=NVIDIA Corporation, renderer=GeForce GTS 250/PCI/SSE2, version=3.1.0
gl: (viewport=8192x8192) (texturesize=8192) (stencil=8)
gl: extensions=GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_instanced GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_framebuffer_object GL_ARB_geometry_shader4 GL_ARB_imaging GL_ARB_map_buffer_range GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_shadow GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_transpose_matrix GL_ARB_vertex_array_object GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_bindable_uniform GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_object GL_EXTX_framebuffer_mixed_formats GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_shader_objects GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_sRGB GL_EXT_texture_swizzle GL_EXT_texture_shared_exponent GL_EXT_timer_query GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KTX_buffer_region GL_NV_blend_square GL_NV_copy_depth_to_color GL_NV_copy_image GL_NV_depth_buffer_float GL_NV_conditional_render GL_NV_depth_clamp GL_NV_explicit_multisample GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_framebuffer_multisample_coverage GL_NV_geometry_shader4 GL_NV_gpu_program4 GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_coverage GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_parameter_buffer_object GL_NV_parameter_buffer_object2 GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_texgen_reflection GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_expand_normal GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_transform_feedback GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NVX_conditional_render GL_NV_vertex_buffer_unified_memory GL_NV_shader_buffer_load GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum GL_WIN_swap_hint WGL_EXT_swap_control
wgl: extensions=WGL_ARB_buffer_region WGL_ARB_extensions_string WGL_ARB_make_current_read WGL_ARB_multisample WGL_ARB_pbuffer WGL_ARB_pixel_format WGL_ARB_pixel_format_float WGL_ARB_render_texture WGL_ATI_pixel_format_float WGL_ARB_create_context WGL_EXT_extensions_string WGL_EXT_framebuffer_sRGB WGL_EXT_pixel_format_packed_float WGL_EXT_swap_control WGL_NV_float_buffer WGL_NV_multisample_coverage WGL_NV_render_depth_texture WGL_NV_render_texture_rectangle
gl: extensions=(lockarrays) (multitexture) (pointparameter) (vertexbufferobject) (separate color) (anisotropic filter of 16.00) (compressed texture) (cubemaps)
wgl: extensions=(wglpixelformat) (wglrendertexture) (swapcontrol)
gl: reducing max texture size from 8192 to 2048
tmsystem: fullscreen modes=(640x480x32x59) (640x480x32x72) (rj-720x480x32x59) (rj-720x480x32x60) (rj-720x480x32x60) (rj-720x480x32x60) (rj-720x480x32x59) (rj-720x480x32x59) (rj-720x480x32x56) (rj-720x480x32x56) (rj-720x480x32x56) (rj-720x480x32x72) (rj-720x480x32x72) (rj-720x480x32x72) (rj-720x480x32x75) (rj-720x480x32x75) (rj-720x480x32x75) (rj-720x576x32x60) (rj-720x576x32x60) (rj-720x576x32x60) (rj-720x576x32x59) (rj-720x576x32x59) (rj-720x576x32x59) (rj-720x576x32x56) (rj-720x576x32x56) (rj-720x576x32x56) (rj-720x576x32x72) (rj-720x576x32x72) (rj-720x576x32x72) (rj-720x576x32x75) (rj-720x576x32x75) (rj-720x576x32x75) (800x600x32x60) (800x600x32x72) (1024x768x32x60) (1024x768x32x70) (1024x768x32x75) (1152x864x32x60) (1152x864x32x75) (1280x720x32x59) (1280x768x32x60) (1280x800x32x60) (1280x960x32x60) (1280x1024x32x60) (1280x1024x32x75) (1360x768x32x60) (1600x900x32x60) (1600x1024x32x60) (1600x1200x32x60) (1680x1050x32x60) (1920x1080x32x59) (rj-720x480x16x59) (rj-720x480x16x60) (rj-720x480x16x60) (rj-720x480x16x60) (rj-720x480x16x59) (rj-720x480x16x59) (rj-720x480x16x56) (rj-720x480x16x56) (rj-720x480x16x56) (rj-720x480x16x72) (rj-720x480x16x72) (rj-720x480x16x72) (rj-720x480x16x75) (rj-720x480x16x75) (rj-720x480x16x75) (rj-720x576x16x60) (rj-720x576x16x60) (rj-720x576x16x60) (rj-720x576x16x59) (rj-720x576x16x59) (rj-720x576x16x59) (rj-720x576x16x56) (rj-720x576x16x56) (rj-720x576x16x56) (rj-720x576x16x72) (rj-720x576x16x72) (rj-720x576x16x72) (rj-720x576x16x75) (rj-720x576x16x75) (rj-720x576x16x75) (1440x900x16x60)
directinput: searching joysticks=none
tminput: searching for input devices...(1)
tmsystem: searching usb interface (0) 0=radiointerface
tmsystem: searching usb interface (1) 1=unable to open interface device
tmsystem: searching usb interface (0) 1=unable to open joystick device
tminput: 1 devices found
tminput: searching for input devices...(2)
tmsystem: searching dummy usb interface (0) 1=unable to open interface device
tmsystem: searching dummy usb interface (0) 1=unable to open joystick device
tminput: checking for joystick 0=fail
tmgl: loading font v2 texture/arial20b.tmf=(256x256) (32x255) ok
sim: loading scenery scenery/winzeln.geo...
sim: 1 objects 0 dynobjects
sim: start position 1 (not for helicopter)
sim: start position 2 (not for helicopter)
sim: start position 3 (not for helicopter)
sim: start position 4 (not for airplanes)
sim: load texture grid 5x5 (compress=1) named winzeln/winzeln=(5x5) (24x13) (72.00 36.00) (3.00 3.00)
sim: sphere params=-1.5000 0.0000 -0.7000
sim: loading ground object scenery/winzeln/winzeln.obj=ok
sim: loading time=38010 mus
tmcollision: 1604 triangles using 109072 bytes
tmcollision: omin=(-5000.0,-5000.0,-2.1) omax=(5000.0,5000.0,59.6)
tmcollision: octmin=(400.0,400.0,400.0)
tmcollision: otnodes=37 otdepth=11
tmcollision: otnmaxareas=838 otnavgareas=48 otnminsize=(312.500,312.500,61.746)
tmcollision: otareas=1801 mem=100856
tmcollision: otclppl=5604 mem=179328
tmcollision: 37 octrees, using 9620 bytes
tmcollision: total mem=398876 bytes
tmcollision: time=5629mus
tmcolldynamic: no dynamic objects or triangles
sim: loading aircraft 1 christeneagle...
tmdairfoil: loading naca0015 ok
tmdairfoil: loading flat ok
tmdairfoil: loading naca0009 ok
directsound: register sound sound/g15-3000.wav=ok
directsound: register sound sound/g15-5000.wav=ok
directsound: register sound sound/g15-10000.wav=ok
generating shadow christeneagleshadow0=radius=2.13 bbmin=(-1.28 -1.28 -0.46) bbmax=(1.28 1.28 0.27)
sim: creating blurr=Propeller
loading input device calibration config/radio0.tmc=ok
tmmusic: off
tmsystem: calibrating radio deviations= 0 3 6 9 -16 25 (timer=16966) -36 4) 88 (BBD5FC9E)
directsound: shutdown
directinput: shutdown
saving configfile config/main.mcf=ok
saving player configfile config/player1.mcf=ok
tmsystem: 0 memory blocks:
tmsystem: shutdown, 0 memory blocks left using 0 bytes
4 GB
64
Problem signature:
Locale ID: 1033
afdesign: init ok
init pixelformat=ok
tmmusic: off
Moderator
My Feedback: (58)
Hi Bob, if you do not have any addons, patch 1.8.0.25 will be what you need. I would suggest that you uninstall AFPD using the instructions at the bottom of this page http://www.aerofly.com/downloads.html and then reinstall AFPD followed by patch 1.8.0.25
ME
ORIGINAL: rajul
Anyway, AFPD looks good on my new HDMI monitor.
Moderator
My Feedback: (58)
Hi Bob, the other patches will not make a difference if you do not have any addons. On the AF5, I'll provide more info later. Your system should be able to handle AF5 without any problem. You can upgrade from AFPD to AF5 if you wish in the future, but by itself AFPD is great and I believe it will remain as the benchmark simulator especially for lower spec systems.
