Ikarus and JR 12x USB wont recognize radio.
My Feedback: (7)
TX
I have installed the program and everything seems to be right, but when I plug my radio to the usb of the Ikarus, it wont recognized. It says no radio connected.
please help any one. Let me know the procedure.
Manuel
Manuel
My Feedback: (7)
TX
RE: Ikarus and JR 12x USB wont recognize radio.
Mike, thanks for getting back to me so quick to help me. Excuse my ignorance, what is PPM mode? And also here Im sending you the picture of the USB connections.
Manuel Rodero
Manuel Rodero
My Feedback: (7)
TX
Mike,
Im looking at the manual and on that ppm setting, is that on the 2.4 dedicated only 12x tx ? or is it on the other older 12 x that has the 72 mhz also?
Thanks again
Manuel
Thanks again
Manuel
Moderator
My Feedback: (58)
Are you using the 2.4GHz or 72MHz version? If it is the 2.4GHz version, there is nothing to set in the radio. If it is the 72MHz version, pls check your manual on how to set PPM mode. In either case, pls disable the trainer mode.
Pls also follow the attached connection diagram.
My Feedback: (7)
TX
Ok. Ill have to order that other connection that I dont have.
Thanks for the info Mike, I really appreciate it.
Manuel
Manuel
Moderator
My Feedback: (58)
You could also use the AFP-02 adapter which is lower in cost http://www.fxaeromodels.com/product_...oducts_id=1659
My Feedback: (7)
TX
Hey Mike,
Thanks, I was just going to order from Tower, but they dont have the plug in stock, Im glad you are telling me abour this other plug. So thats the problem? that Im missing that plug? Now I have the 2.4 only ok.
so I dont set any thing else correct?
My Feedback: (7)
TX
Ok. Mike I got the cable, it works now with my DX-7 but wont work with my 12X. On the DX7 it show 7 channels right away, on the 12 x it never stops scanning channels.
That really doesnt worry me anymore, Im fine with the DX7. My main problem now is that I cant set up the heli mode. I fine that there are many functions that cannot be used on a Mac. And this package does not bring a Ikarus Mac version manual. I cant get every channel to work the swash plate the right way. Any secret to this set up?
thanks again for all your help.
Manuel
Manuel
Moderator
My Feedback: (58)
Hi Manual, I do not have access to a 12x radio to test it out. I would suggest that you post a question in the JR/Spektrum support forum to get an idea how to set it up for a flight sim http://www.rcuniverse.com/forum/forumid_116/tt.htm I would be interested to find out myself.
Have you installed the latest patch 1.11.7.31?
You should be able to find the softcopy of the instruction manual in the AFPD main directory. Pls go through the setup and calibration procedures.
