Revert function for AF5
Mike i'm getting involved with some of the edit features and have a question. When i edit a value and then attempt to use the REVERT function for that item the data block never changes in value? How is it expected to work and i'm assuming it reverts back to the value of the un-edited model or?
I've tried to revert data in both the expert and simple modes but no luck...i even tried to revert the entire model but no changes were noted in any data blocks...thanks. |
RE: Revert function for AF5
I have to test this and come back to you later
OK, i'll be here.
The revert-button only has the following functionality:
After editing some parts/parameters (without clicking "Test") clicking "revert part" brings back the parameter values as they were ON OPENING THE EDITOR. The button is meant to be used if a part/value got messed up while editing. Especially in engine or Aerodynamic interactive plots. If you "Test" once, you cannot go back. If you want to do editing with testing, the following procedure is recommended: 1. Save Model as ... and give it a description you like. 2. Edit some values, click "Test" if you like the changes, save the model if you don't, reload the last saved model or remember which parameter you changed and try other values. |
Thanks for the clarification Mike.
