AeroFly 5.5.0.7 not work with DX7 on iMac.
Hello.
I have AeroFly 5.5.0.7 and iMac (i test on Mac Pro too). When i connect my DX7 i see - USB Interface - 12 Chanels !!! And when i click Calibrate... nothing happened. I use this adapter and original USB. http://www.atlantahobby.com/Store/pc...Adapter_lg.png<br type="_moz" /> |
RE: AeroFly 5.5.0.7 not work with DX7 on iMac.
Please post a photo of all the cables that you have.
1 Attachment(s)
Was there any error message from AF5?
Leave the DX7 switched off before plugging in the adapter cable. The radio will automatically switch on when the adapter cable is plugged into the radio. The radio will not work with AF5 if it is manually switched on before inserting the adapter cable.
I try.. The same result.<div>
</div><div> </div> |
What error messages are you getting from AF5? Did you disable the student/trainer mode in your radio?
1 Attachment(s)
Yes trainer mode is off.
I see this... And nothing work. |
PM me your contact details
Ok i send my e-mail<div>
</div><div><span style="font-family: Arial, Verdana, sans-serif; ">Today i buy New IKARUS Y-Adapter... but nothing work again.</span></div> |
Hello.
You forget about me? I send to you e-mail all documents ...<br type="_moz" /> |
I did not receive any email from you so far. If you do not have my email, send a PM to me
I'm having the same problem, but probably because I a total newbie. I've been scouring the net for some guidance, and it's a challenge. I believe I have the proper cables. I would really like to see a FAQ or some sort of instruction. I have a Mac Pro, and the sim is not seeing the radio. I have the dongle (should I use black or red, as they are unmarked) connected to the plug that has a three prong extension, out to the 3.5/2.5 cable, attached to the Y cable (Part number 31036) and plugged into the DSC plug on the radio.
Any help would be most appreciated! Paul |
Paul, please abide by the forum rules shown at the top of the forum
Hi Rajul,
I am from france and I have exactly the same problem. i have just bought Aerofly 5.5 and it doesn't works with my new DX7S Can you help me ? My config : OSX 10.7 , MacBook Aire 2011 Thanks |
El JB, please start your own thread as per forum rules
I'm new on this Forum how can i do that ?
Tahnks |
To start a new thread, click on the "New Post" button on the top left of this forum
ok here is the link : http://www.rcuniverse.com/forum/m_11...m.htm#11042778
