IMAC Discuss IMAC style aerobatics in here
DUAL BATTERY SYSTEM QUESTION
Reply
Old 04-02-2011, 01:15 PM
DAVE KEPHART
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default DUAL BATTERY SYSTEM QUESTION
I'm running a 9cap transmitter,with a Spectrum ar 7000,a Miracle dual battery switch, running 2 Nimh batteries (1700mah).The question is ?how do I use the 2 (redundant) batteries with this set-up?Do I use a y-harness for the batteries or plug one battery into the power terminal on the recv'r and the other battery into an aux.channel on the recv'r?and will these or another combination give me the redundancy of 2 batteries packs so in the event of a failure the system will still function safely.This system is in my Comp-arf 50c.c. yak
thank you
DAVE KEPHART is offline
Old 04-02-2011, 06:03 PM
Flyfalcons
Flyfalcons's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: DUAL BATTERY SYSTEM QUESTION
Plug each battery into an open slot in the receiver. They will work in parallel (same voltage, double the capacity), and if one gets unplugged or dies, the other battery will power the system.
Flyfalcons is offline
Old 04-04-2011, 04:52 AM
basimpsn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Flyfalcons
For single receiver thats the way to do it, I use two receiver with two batteries.
basimpsn is offline
Old 04-04-2011, 05:03 AM
BarracudaHockey
Community Moderators
BarracudaHockey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yup, two batteries, two switches, one into a spare channel. Since you have a Futaba the DSC port is almost never used and connected to the power bus so that works too.
BarracudaHockey is offline
Old 04-09-2011, 06:56 AM
Mrs R
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
you need to fit a BATSHARE made by SMARTFLY
If you just y lead or equivalent and one pack or even just one cell in a pack ,,paqcks it in it will drain the other pack like a dead short.
Rachael
Mrs R is offline
Old 04-09-2011, 11:47 AM
Lnewqban
Lnewqban's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
http://www.hangtimes.com/parallel_packs.html
Lnewqban is offline
Old 04-10-2011, 02:20 AM
Mrs R
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have another sugestion that has worked with no problems and gives you a number of options at not cost.
Have a look at SMARTFLY's POWEREXPANDERPRO (not sport )
I run this system in both my 50 cc models and have set it up in my 42% EXTRA300 running 2 5000Ma 2s lipo's useing HITEC HS-7950HV servo's all round.
My 50cc set up uses lipo's into 8amp DUALSKY regulators the Board regulates power to the Receiver 5 volts, the system then supplies clean power to the servo's HS-7955TG all round.
These have proved to be very reliable on 36Meg. and 2.4Gig.
Have Fun
Rachael
Mrs R is offline
Old 04-13-2011, 08:57 AM
MTK
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: DAVE KEPHART
thank you
Tech Aero.com
MTK is offline
Reply
Display Modes
