IMAC Discuss IMAC style aerobatics in here
IMAC Pro now in Android Market!
Reply
Old 02-22-2012, 08:35 PM
NiknJen
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default IMAC Pro now in Android Market!
Hey Guys,
The brand new IMAC Pro and the updated IMAC Lite are now in the Android Marketplace!
Here is the Link:
https://market.android.com/details?i...mobile.imacpro
They have been completely redesigned from the bottom up!
The IMAC apps for Android devices are designed to enhance your IMAC experience by giving you valuable resources on the go and at the field with your mobile device.
The all new "Caller Mode" is designed to let someone use the phone to call for you, or to use it for just cycling through the maneuvers. It has each maneuver displayed individually along with the name of the maneuver, and a place to take notes for the maneuver. You can cycle through the maneuvers be either pressing the forward or back arrows or swiping left or right.
The new "Locations" displays a map centered to your location that shows all the contests in the entire US. If you turn on "satellite layer" you can zoom in all the way down to see the actual fields. If you select the contest (press on the trophy icon) it brings up an window that gives you the details and date for the contest along with a "get directions" button that will give you turn by turn navigation to the contest.
There's also videos for all the sequences, rules books, tips, Weblinks, contest resources, text descriptions of the sequences as well as the "offical" pdf's and much, much, more!
At .99 cents for the Pro version I bet it's one of the least expensive but one of the most used pieces in your IMAC arsenal!
Here are some screen shoots:
ID:	1730577   Click image for larger version
ID:	1730578   Click image for larger version
ID:	1730579   Click image for larger version
ID:	1730580   Click image for larger version
ID:	1730581   Click image for larger version
NiknJen is offline
Contact Us Archive Advertising Cookie Policy
