Yaw with new Pitts
My Feedback: (204)
Yaw with new Pitts
I maidened my RC Guys Pitts today, all went well with the exception of a hard yaw to the left, I needed about 20 degrees of right rudder to get it to track straight. when I cut the power the plane stayed on track, especially on the landing, I have about 1-2 degrees of right on the engine, do I need more or can it be something else? the fin is straight
http://www.ssrcfc.ca/trimming.html
Goldsmith trimming. If you have an iphone there is an app called the "Trim App" You can have a caller tell you what to do, for example: to check right thrust angle, fly into the wind and pull to vertical upline, what does the model do? Drift to left, straight, or drift to right. Have your caller check appropriate box. At the end of the flight, you hit "make report" and it will list suggestions. Change only one thing at a time though or you will be chasing and creating new problems.
Short answer, throttle to rudder mix.
My Feedback: (204)
