3 BLADE,STD MUFFLERS,DA150=QUITE ENOUGH FOR IMAC??
My Feedback: (19)
GA
IS IT POSSIBLE TO RUN STANDARD MUFFLERS ON A DA150,WITH A 3 BLADE PROP,AND STILL BE ABLE TO HIT DB LIMITS AT THE CONTEST?????AND IF SO,WHAT IS YOUR SETUP,AND DB READINGS???
CA
RE: 3 BLADE,STD MUFFLERS,DA150=QUITE ENOUGH FOR IMAC??
Hi There,
I consistently recieved a sound score of 10 at a recent big contest while running a 28-12 Airmodels 3 blade prop. During unknown rounds I used a Msc 32-12 2 blade for slower speeds and recieved consistent 5's
With proper throttle management ,you should be fine with just a 3 blade and standard mufflers.
Sorry I don't have any DB#s, just real time contest data............
Dave
Dave
