Great Planes EA 330 Patti Wagstaff 1/4 Scale which engine?
Hi
I just ordered the 1/4 scale Extra 330 "Patti Wagstaff" by Great Planes.[8D]
Does anybody out there have any experience with this model? I am thinking about getting a DA 50 For it.
What do you think?and how does it behave?
NB, CANADA
RE: Great Planes EA 330 Patti Wagstaff 1/4 Scale which engine?
There is alot of info on RC Universe already about this aircraft, just do a search. I have a DA 50 on my Wagstaff and it is a awesome combination. I'm very pleased with the engine, it is very user friendly with great power. The aircraft is the first ARF I have ever owned and extremely impressed with the quality. Great Planes has taken care of all of the initial problems. I did replace some of the hardware and make changes only because I felt more comfortable with my hardware. I strongly recommend installing the Rudder servo under the canopy and using a pull-pull control system as the the C of G will be too far aft. Good Luck
Mike Sebastien
Mike Sebastien
My Feedback: (18)
I like my GPPW, it has DA50 for power and flys great. I like it for imac and pattern work. The DA50 is the best engine I have ever owned. Like said, there is a lot of information here in the ARF forum about building and flying the GPPW.
http://www.rcuniverse.com/forum/GP_P...1027454/tm.htm
Good luck!
Joe
Good luck!
Joe
NB, CANADA
I use mine also for IMAC and to practise Master/Expert pattern, this is the closest IMAC airpalne that I have found that flies like a pattern bird. The reason I use it to practise pattern is that is cheaper on fuel than my Pattern bird which has a Webra 1.6 in it.
Mike
Mike
Thanks for the info!
I'm sure going to get The DA 50 then.
After what you guys say, I'm really looking forvard to crank it up.
I am plannning to enter the model in some competitions next summer, using the winter to get it assembled
and trimmed out, and do some practising of course[8D]
Hi
What about mufflers, have anybody measured the noise level from the DA?
At my club we have a noise limit at 91 dba measured at 9 feet (three meters).That's
not difficult to get below, but "the quieter the better"
Any recommandations?
And what about soft mounts?
Thanks.
Thanks.
