Gas engine for H9 EDGE
ZDZ 40 with the 20x10 prop. one of if not the lightest gas engines for this plane. the G-38 might be less money but probably to heavy.
This plane was not designed for a gasser so you will have to reinforce the firewall and watch the wing loading.
My Feedback: (24)
I've seen one with a zdz40 and it looks clean. I'm sure it has enough power to Hover. Its too bad the plane isn't worth squat. Be prepared for some really nasty stalls, the plane flops around like a wounded bat totally out of control untill you get the airspeed up. Trust me, Your going to freek out the first time it happens.
I have over 200 flights on one with a Saito 180
You may want to create a new leading edge with the proper shape. (Basically less blunt) I've been told thats where the problem is, and reshaping the leading edge will help.
I think the airplane is down right dangerous, and it's being discontinued. Go figure.....
john
john
LA
There is no good gas engine for this plane,like it or not it's true.Especially a G-38,way too heavy,no power.This plane simply was not built or intended for gas.It will be too heavy even with a light gas engine,and all the 1.6-1.8 gassers wont provide enough power for 3D.I know there are people out who are going to say I'm crazy,But trust me I'm not,I've done it.Put your money into an OS 1.60 and you'll be much happier.If you don't believe me just do the gas thing and you'll see.If all you want to do is hover and basic aerobatics you might get away with it,but harrriers,elevators,inverted flat spins,etc. will be a no way.If you are interested,here is a link to H-9 Edge with a ZDZ 40,be sure to read the part where he says he does not recomend this combo. http://www.concentric.net/~Dhmodels/workshop6.htm
Mike.
Mike.
My Feedback: (21)
Dont worry about its flight characteristics. They are awsome, all the old planes had bad wings, now they all have the new wings and fly much better. I also recommened using a os 1.60fx like Im using. You will be much happier
My Feedback: (21)
I'm telling ya man, they don't tell you a recommened engine size for nothing. They spend lots of time testing with different engines to find what works the best. And Ive researched and I can't find any engine that fits this edge better.
Moki 1.8 is strong, very strong but 12 OUNCES heavier!
any gas engine would be very heavy and have a negative effect on its flight characteristics
a saito 1.8 would be cool, but i dont have 30$ for every 1 gallon of fuel, not to mention it doesnt have as much power as the os 1.6
anyway you look at it the os seems the best, except for fuel consumption, but thats the price im willing to pay for best flight performance
My Feedback: (24)
shortman is right, the Saito 180 burns fuel. 24oz tank last about 10 mins. go for the 0s 160. Mine flew like crap, and so does my friends, but I guess some people have them flying straight. I hope you have good luck.
I'll have another Edge 540. but it won't be a H9
MT
JRJOHN
The issue is not the leading edge...It is the twist in the wings...The ones that arent flying well have a twist in one or both panels..put an incedence meter at the root first..either side..now compare the other root..now move your meter 4inches over till you get to the wing tip..i put small masking tape pieces at each spot and put the degree #s on the taps so I could get a better overview...Now do the opposite side...On My wing That did what you are saying..staling at the tip ..droping the tip..whatever we want to call it..the side that droped first was the panel...are you ready for this..IT HAD 2 DEGRS. OF WASH-IN...WASH-IN..DAH that is why we are having so many problems...Now my new wing has wash out..3/4 degree diffrence between the two tips..and be carefull the roots being lined up does not always give you the same incedence on both sides.
I will be putting this on a new thread for all to read later..
Scott
Scott
My Feedback: (21)
the OLD VERSION wings had problems, these new wings are perfectly fine, the old ones the shear webs were in the wrong direction, my h9 edge is perfect, but listen to skerlok
My Feedback: (8)
MI
I have to agree. The H9 Edge 540 is not made for gas. I ran mine with a Saito 180. It did nicely but didn't waterfall as easily as I would have liked it to. I put in a Brison 2.4 Gas engine. Just made the plane heavier, not necessarily better.
I sold the Edge and bought a Dave Patrick 330L w/ Brison 3.2. That was a much better engine/plane combination, but I'm already set to sell that one too. Since June I've been flying a 1/3 scale H9 Cap 232 with a Mac Minarelli 85 (electronic ignition added). Now here's a combination that makes waterfalls a breeze at half throttle.
Dale
Dale
the lightest / powergasser is a MAckay 30cc.... stunning engine.... see www.moki.co.uk ......... I certainly wouldn't go with anything else, and believe me I know what im on about
Mine's scheduled for a change to one of these soon, post having flown one recently with this engine.
FL
Welsh3D:
I assume you were very pleased with the 30cc engine.
I have the 1.4 RCS (Moki) on my Hanger 9 edge and it flies great but I would like to add a few more horsepower without going to a light 40.
Can you elaborate a bit on the flight performance with the 30.
Here is the RCS link, should be the same engine.
http://www.rcshowcase.com/RCS%20180%20.htm
FL
There is nothing wrong with the design of the H9 Edge 540. The only problem is that some of the planes have been coming with warped wings or with leading edges that do not match. It is not the round leading edge that is causing the stalling. Actually a blunt leading edge is more stall resistant than a sharper one.
Ditto on keeping this plane light. Try to stay under 13 pounds for good performance. The one that I have has an OS 1.60 FX w/slimline pitts muffler running an 18x6W APC. I have fully unlimited vertical with this combo on 5% fuel. My plane weights in at 12.25 pounds and it performs 3D very well. It does not have any tendicy to tipstall. It just mushes forward in a stall. Very easy to control elevators and harriers. This plane does a perfect wall. It seems to rotate on the wings cg. In all I believe this to be one of the best 1.20 size planes for 3D.
My Feedback: (24)
I know I was really negative about the h9 Edge, and for good reason. But I will tell you one thing. Horizon Hobby stood behind both broken wings, they replaced everything that was damaged. And they didn't give me a hard time. I can't say enough good about Horizon. They are first class. In the end thats what really counts. If they build a 1/3 scale Edge, I'll be one of the first to buy it.
John
Dare to be different
John
WI
jrjohn
Thanks for the well-wishes and nice thoughts, wish I could tell you which wings this plane has, but it hasent even been shipped to me yet, I was asking about an engine for it when this thread started ( it had saito 1.80 but i got airframe only) People have some strong feelings for this aircraft and H9, I'll be happy to own this plane just for the conversation.
Randy
For longer yet to eye it
still too scared to fly it
Randy
My Feedback: (24)
Randy, You got that right! there are definatly some strong feelings about the plane! At times I loved it, other times I hated it. I had hundreds of flights on mine. I always prided myself with being able to recover from it's sudden stalls with no prior notice. Last Saturday It all ended. I stalled and put it straight into the mud. I never knew what hit me. It looked like somebody spilled a box of toothpics. Damm that thing, how dare it make a fool of me in front of 15o people at a flyinn. I'm still pissed off.
If you have a bad wing, you'll swear your radio is screwed up, or there's a gremlin on board. it's neither. I hope you have a good one!
