Throws for 40% Yak
RE: Throws for 40% Yak
Hello,
If your plane if the Aerotech Yak54. I have one and I have the following setup:
Ailerons - Low Rate 1 1/2" High 2 1/4" Expo negitive 30%
Rudder - Low Rate 30 degrees High 50% Expo negitive 60%
Elevator - Low rate 1 5/8" High 3" Expo 46% negitive
CG is right in the middle of the wing tube. The Plane float's with this CG very stable. I have 3% Aileron to elevator mixing. Be careful this plane floats in on landing so if you have any kind of wind you don't make any long approach's. Have fun I like mine for sure.
David
David
