Linkage Question
Linkage Question
This may not be the place for this question... if so... sorry.
Have taken a break for a year or so and am now trying to put together another plane.
What are you using for linkage connections now?
A year or two back I was using a heavy duty black plastic connector on each moveable surface. If memory serves, the manufacturer retired and sold the product to dubro? , I think?? Seaching the dubro site, I found the swivel ball connector for the servo end, but not what I remember for the moveable surface end. Sorry, but my memory if failing me on names and labels....
So... if someone could direct me to what linkage is current for 30 to 40% planes... I'd be much appreciative.
Thanks in advance,
Tony
Thanks in advance,
Tony
RE: Linkage Question
I found something very similar on the Horizon website.....
http://www.horizonhobby.com/Shop/ByC...ProdID=HAN3614
Any other current solutions?
My Feedback: (54)
John Mitchell at http://www.aeroprotect.com/ handles hardware and other goodies for giant scale planes. I think you used to use Rocket City hardware. It is still being distributed by Nelson Hobbies but Aeroprotect carries all the sizes you will need if you don't want to go directly to Nelson.
My Feedback: (41)
I've used the Hangar 9 stuff you've posted the link to, as well as the DuBro units and I'll post a link of those at Tower.
http://www2.towerhobbies.com/cgi-bin...&I=LXDCU2&P=ML
I like the actual connection of the Hangar 9 stuff a little better, but they are short and require special attention to getting the pivot point lined up with the hinge line. Usually you drill through the surface at an angle; i.e. 90 degrees to the top surface which leaves a bigger angle to deal with on the bottom.
The DuBro stuff is longer and can actually be trimmed to length and re-drilled where you want the hole, so drilling through perpendicular to the chord line can be done.
I've not used the Rocket City stuff since I'm new to this GS stuff, but I suspect I'll be looking at it somewhere down the line since I see so many references to it on these forums.
My Feedback: (8)
MI
I prefer the Hangar 9 horns. They are exactly like the old Rocket City horns using a sleeve instead of a ball link like the ones Nelson and Aero sell. The ball link will make the clevis rotate on the screw and deflect when in a push motion.
The linkage setup I'm using for my Carden Yak's is a direct drive system. The linkage is eliminated. No slope other than the servo itself.
Check it out at DurantDirectDrive.com. I will be posting pics next week with the system installed.
Rick
Team Futaba
