PCM radios
PCM radios
I am useing a Futaba T6XA Radio and if I was wanting to fly with a PCM . would all I have to buy is A PCM receiver ? and would the Crystle in my FM receiver work in the PCM. and what is so great about PCM/?
thank you ,
thank you ,
NC
RE: PCM radios
The "Dual-Conversion" crystals are what you need for the PCM receivers. These are the same crystals that work in the DF (dual conversion FM) receivers.
[link]http://www.futaba-rc.com/radioaccys/futl20.html[/link]
My Feedback: (34)
CA
RE: PCM radios
PPM is "regular" FM...frequency modulation. PCM is a totaly different type of modulation and you need a different transmitter to make that happen.
The nice part about that is every PCM transmitter I know of can be switched to transmit in PPM, so all of your regular FM receivers can still be used. Most PCM radios have a several model memory.
The main benefit with PCM are the failsafe settings...if you lose control of your model the RX will move the servos to a preset position (set by the user) or hold them in the last position sent by the transmitter. Each channel is set individually (i.e. throttle to idle if signal is lost).
Someone else can probably give you a more scientific explanation.
NC
RE: PCM radios
ORIGINAL: WhirlyGirl
Think of it this way, if you use a DSC cord to connect the transmitter to the receiver, you will be sending the PPM or PCM pulse train to the receiver before it is modulated to RF (radio frequency). Without the DSC cable, the transmitter then modulates the pulse train to the RF frequency, and all modern radios that I know of use FM.
I have an older Ace Silver Seven radio, and I can use either AM or FM RF decks. Either way, the encoding scheme is the same -- PPM.
Having said all of that, it is generally understood that PPM stands for FM.
PPM uses pulse widths, or "pulse positions", to indicate the servo position information. Decoding this is simple, each pulse is separated and sent directly to the corresponding servo. One long pulse is used to indicate the end of a pulse frame, the next pulse will then be channel 1, the next is channel 2, etc.
PCM takes the channel information and converts it into codes, very similar to the way two computers communicate via serial ports, with error-checking. The information is in a proprietary binary format, and each channel position is represented by a number (10 bits, or 0 to 1023 for most radios). Several numbers (channels) will be sent together as a frame. Additional information is included at the end of each frame that is used to verify the frame was received correctly by the receiver (I don't know the exact scheme, whether it is checksum or CRC). This is how the failsafe feature works, by being able to differentiate between good and bad frames. PCM receivers must have a microprocessor to work, and this is one reason why they are more expensive than the regular PPM receivers.
To get back to the original question, according to Futaba's website, the 6X transmitter can do either PCM or PPM. You will need a receiver that matches whichever mode (PCM or PPM). If the corresponding PPM receiver is a dual-conversion type (designated by a DF in the model number) then you can move the crystal from the PPM receiver to the PCM receiver.
