can someone identify this Sukhoi?
QC, CANADA
Hello,
I recently acquired a bunch of used planes, among them was this Sukhoi. It has about 56.5" WS and is missing the canopy. Anyone has an idea who makes this plane? I installed an old ST90 and will be using it to practice some IMAC manouevers when Spring comes before dusting off my big IMAC machines.
Thank you
Thank you
My Feedback: (37)
MI
RE: can someone identify this Sukhoi?
Maxime,
You have an old Model Tech Sukhoi Su-26MX ARF. They have been out of production for some time . I am not sure if they will have a canopy for it any longer, but it may be worth a call. If they do not have one I would try to fit an old Sig Sukhoi cowl to it, they had one about the same size.
Good luck hunting.
Good luck hunting.
QC, CANADA
ORIGINAL: budgetdude
Check out that amazing automatic aileron mixing/coupling device. Is that a special servo for that kind of set up.
Your post worked, I did look back again on the photo
