Bakersfield "Bear Mountain Flyers" IMAC
Registration is open for the Bear Mountain Flyers IMAC!
http://www.imacwebscore.com/2006Bakersfield/index.php
March 18-19, 2006
Hosted by the Bear Mountain Flyers of Bakersfield, California
Tim Attaway, Contest Director
Mark Lattimore, Coordinator
Sanctioned by the Academy of Model Aeronautics.
Contest entry fee: $50
Entrants must register online and also complete and mail in the official entry form. Entry fees to be paid, in advance, by check. Payment details are on the paper entry form. Registration will open on February 24, 2006 and will close on March 11, 2006.
Your entry fee will be refunded if you officially notify Tim Attaway or Mark Lattimore with your regrets prior to the contest.
The Bear Mountain Flyers Spring IMAC is a 2006 Southwest Region Season Point Title Challenge event.
The contest will be conducted using 2005-2006 AMA RC Scale Aerobatics rules. The 2006 IMAC Known Sequences will be flown. Rules and sequences are available at www.mini-iac.com.
Sound testing will not be done. We will not be giving a Sound Score.
The Zoneless Box rules will be used. We will not be giving a Positioning Score.
A pilot and instrument panel will not be required.
All pilots will be expected to judge, scribe. Be sure to sign up for your volunteer position online.
Contest officials will plan for the normal number of sequences of 6 knowns and 1 unknown, with 2 throw aways knowns. However, at 55-60 or more pilots in attendance we will consider reducing the knowns to 5, or even 4, depending on the time and logistics adjustments that need to be made relative to the pilot numbers. One (1) throw away known if that occurs.
The field will be open for practice on Friday, March 17th from 8:00 a.m. to Dusk.
RV's welcome. No hook-ups available.
Food and sodas will be available at the field for lunch.
Regards,
Anna Wood
IMAC SW Region
Assistant Regional Director
March 18-19, 2006
Regards,
Anna Wood
IMAC SW Region
