Pull-Pull cable Q
BC, CANADA
Pull-Pull cable Q
Hi folks
Had my rudder cable snap on my 84' Yak 54 and have some plastic coated Kevlar cable kicking around the shop. Before I spend the time and effort has anyone tried using this instead of the braided steel version? Pros/cons?
Dave
Dave
RE: Pull-Pull cable Q
Dave,
It will be simpler to install, for sure. I can tell you that I had uncoated Kevlar on an 84" Edge a few years ago with no problems. I always watched for fraying, but never saw any. I can't imagine why it wouldn't work.
Ken
Ken
BC, CANADA
Thanks for your input guys. I replaced the cable today (with Kevlar) and will fly it this weekend.... and yes it will stretch to a point then settle. At least that is what I have found on the pattern ships.
WA
Try plastic coated steel fishing leader material - in the 80 to 100# test range.
Berkley is a common brand carried at well stocked fishing outlets. They sell
the crimps as well.
the crimps as well.
BC, CANADA
Well so far it's working just fine. The plastic coated Kevlar cable "just" made it through the eyelet hole of the coupler. I tied a knot and then inserted the threaded rod into the coupler for a very secure attachment. It is not coming out.
My buddy Mark had a similiar failure [&o] and replaced his as well. I'll report again if either fails again.
Safe flying.
Safe flying.
