Need source for high flex high temp tubing
Need a source for 7/8 ID high temp tubing (metal or non-metallic) to couple engine header to muffler inlet tube. 2 to 3 inch length. Any ideas?? Just a small misalignment - about 20 degrees of bend required over 2 to 3 inch length.
Joe,
Check with McMaster-Carr. You can get some silicone tubing from them in a variety of ID/OD combinations and it is pretty cheap.
Ken
Ken
Banned
Horizon Hobby offers a Flexible Exhaust Pipe used for Saito engines. Not sure if that will work in your application but it's a thought. It's probably too long for what your wanting...
http://horizon.hobbyshopnow.com/prod...d=SAI182TD1111
Hey you guys going to the Internet Fly-In in June?
http://www.internetflyin.com
