Snapping at top..
CA
Snapping at top..
Made first flight today with Sig 300XS (Saito 150). Real good flight behavior, except for the top of a tight loop...spap rolls to the left. Anyone care to list the conditions that lead to this behavior so I can find a resolution path?
Thanks!
Thanks!
Snapping at top..
We haven't noticed the situation you've described but it could be caused by a number of things, CG, elevator throw, pulling too tight a loop etc. Just get the CG somewhere in the recommended range and fly the plane. Get accustomed to it and then start experimenting.
CA
Snapping at top..
My gess is there is a little washout in the wing tips to prevent it from stalling on slow landings. But invert the wing and slow it down at the top of a loop and Bingo the wing stalls causing a snap.
As the other guys say, use less elevator and carry more speed through the top of the loop.
ME TOO!
i have a clipped wing cub that initally had the same characteristics...and when youre not expecting it - WOW...what a surprise...and whats more - when you think you should PULL out of the snap...it only gets worse - spiralling down to the ground...
sure enough - too much elevator...now shes predictable and still very aerobatic...
but it was certainly an eye opener!!!
