Basic Setup for 50cc IMAC
My Feedback: (178)
NC
What is a good basic setup for a beginner IMAC pilot, especially prop and throws.....plane is an Airwild Edge 540T with a DA 50? Thanks for help and ideas....WC
GA
RE: Basic Setup for 50cc IMAC
Mezjlik 23x8 for the prop......
throws?
always less than you think.
10 to 12 degrees on the ELE....
around 20 degrees on the ailerons
around 35 for the rudder (I flip a switch to higher rate for Hammerheads)
I also use a snap condition to change the rates for snaps based on stick and throttle positions, but no need to complicate it now......
the above numbers are just a starting point... season to taste...
throws?
GA
How far are you from Charlotte? There is a contest up there in a few weeks... just come on out and there will be PLENTY of people that would be happy to help out!
