IMAC Discuss IMAC style aerobatics in here
minimum size for IMAC planes
Reply
Old 09-03-2009, 04:40 AM
lassecfc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default minimum size for IMAC planes
hey guys..
what is smallest/minimum size for IMAC planes in sportsman??
lassecfc is offline
Old 09-03-2009, 06:06 AM
bubbagates
My Feedback: (32)
bubbagates's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: minimum size for IMAC planes
ORIGINAL: lassecfc
hey guys..
Thee really isn't a size limit, however the plane must resemble a plane that has or could fly in an aerobatic box. We currently have a 60 size electric Extra in our region that flies Sportsman and he does well with it. He does fight wind harder than those flying 50cc planes and heavier, but he does well.
One thing to remember in IMAC, light weight is not always good. Weight allows better penetration in high winds. In our region and I suspect most others, we will not even consider not flying until the wind hits around 20mph to 25mph and then we'll hold a vote. A 10lb plane is going to be hard as heck to fly in that wind.
If you are just starting out, I would go and start in Basic. It's a bring and fly what you have type of class, any plane can be used. Don't let the term Basic fool you. It's a lot harder than it looks. Once you get into Sportsman and above, you get to fly unknowns and if you are not familiar with Aresti, then that can bite you as typically the unknowns can change the outcome of a contest quickly. The unknowns are handed out the night before you fly them, you do not get to practice them at all, excet with a stick plane.
Basic does not do unknowns.
Remember this, you must always fly a perfectly wind corrected line at all times (horizontal and vertical), the wings must remain level at all times. Do your first contest in basic, then go to sportsman if you do not feel challenged enough
I know I went past the original question, but that question lead me to think you are just starting, if not then I apologize
bubbagates is offline
Old 09-03-2009, 08:56 AM
lassecfc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
we dont have IMAC in denmark yet... 19 sep. we have the fist IMAC introductionshow..
http://www.rc-unionen.dk/nytforum/to...TOPIC_ID=43610
lassecfc is offline
Old 09-03-2009, 09:42 AM
bubbagates
My Feedback: (32)
bubbagates's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: lassecfc
Congrats!!!!
Old 09-04-2009, 09:17 PM
NJRCFLYER2
My Feedback: (42)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
We fly pattern contests in winds greater than 25 - 30 mph at times, with models weighing under 11 lbs. Not a problem. My 2M Prestige weighs under 9 1/2 lbs and handles high winds extremely well. In fact, lighter weight can work to your advantage. For example, when you are trying to hold a wind corrected vertical line, more vertical speed allows you to accomplish this with a smaller correction angle than if you are flying slower because of having a heavier airframe to haul upstairs.
What you really want is an airframe / engine combination that is light and powerful, which makes it easier to adjust the size of the pattern that you present in varying conditions. When conditions are calm, you generally want to be in closer and flying more slowly than when it's windy, where you want to move the entire sequence out and fly bigger, with more energy and speed. This allows you to wind correct more easily, and also hide bobbles and corrections better. When you have a heavy airframe, you lose this flexibility.
NJRCFLYER2 is offline
Contact Us Archive Advertising Cookie Policy
