Carbon Fibre Exhaust Systems
The Carbon Exhaust systems may be purchased through myself Mark Leseberg Jr. or through Dalton Aviation and Tony Russo in Florida.
The Carbon exhaust systems are currently the lightest system on the market with great results in testing two separate systems.
The First system is a rear outlet system with lightweight milled caps for an extremely light design. The rear outlet has the best sound in my opinion. You don't get the metal 'ting''ting" sound with other cans.
The second system is a front drop back exiting closer to the motor. This system sounds more like an outboard motor on the back of a boat.
The rear exhaust cans have been tested on grass DA 150 Mejzlik 32X10 94 db. Bear in mind that these readings depend on temperature and elevation. (Density Altitude).
In the air the rear exhaust outlet system is the quietest system I have flown.
Both systems are fully tested and proven.
Heat is NOT a problem.
Both systems may be mounted to DA and 3W Engines.
Currently 150 size motors may be accomidated.
100 size systems are very close.
You can call Me at 702-528-4469
or Tony Russo at 727-393-3212
Pics of the mufflers are on my site www.marklesebergjr.com
Thank YOu all for your inquiry.
