RC FLUX XS Savage Flux
Hi All,
I have purchased Hpi Savage XS flux in OCT 2012. I use lipo 3S 11.1V 3800 mah battery. 24t pinion gear and 48t idler gear. THe problem is each time i play the pinion gear slips from the motor dont know why. please suggest Thanks<br type="_moz" /> |
RE: RC FLUX XS Savage Flux
You need to use blue loctite on the set screw that holds the pinion to the motor shaft.
Apply a little red loctite to the motor shaft before sliding the pinion on,
I had this problem happen a couple times on my xs ss, Now it never moves, just use a pinion gear removal tool to get it off the shaft when you need it off. |
