Jet Central Turbines - Artes Jet Jet Central Turbines formerly the Artes Jet forum
Best Place for fuel filter
Reply
Old 06-20-2011, 04:44 PM
FenderBean
FenderBean's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Best Place for fuel filter
The one in my rhino was pretty small, only possible to get 4mm tube on it. The diagram shows it between valves and turbine. Is the best place or would it be better somewhere else? I do filter from jug to fuel cells as well. THanks my rhino runs great on the bench will be in the jet this weekend woot!
FenderBean is offline
Old 06-20-2011, 06:43 PM
bcovish
My Feedback: (8)
bcovish's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Best Place for fuel filter
IMO the best place to put it would be where the manufacturer said to put it. IMO
bcovish is offline
Old 06-20-2011, 07:01 PM
FenderBean
FenderBean's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well not everything in the book has been correct, as far as the diagrams. It shows the manual shutoff in wrong location, so I figured I would ask is all. I would agree normally I just follow the instructions.
Old 06-20-2011, 08:19 PM
rcjetsaok
My Feedback: (7)
rcjetsaok's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It shows a filter between the Fuel solenoid valve and the engine, and no filter between the Gas solenoid and the engine... I think I would filter before the Tee so both inputs are final filtered... I would holler at Eric on this... Doesn't seem right to me either. If it is, I would like to know the reasoning behind it.. The Gas line from the valve is 3mm and I would think the injectors are smaller for the Kerostart therfore the filter would seem more important on that one......??? Cofused....
Danno
rcjetsaok is offline
Old 06-21-2011, 07:15 AM
Edgar Perez
My Feedback: (13)
Edgar Perez's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Fuel filter before the turbine.. so that it catches any metal from the gears wearing out.
Edgar Perez is offline
Old 06-21-2011, 08:22 AM
FenderBean
FenderBean's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ahhh okay that makes since thanks Edgar, now i just have to figure out how to get that 4mm tubing over that filter. I tried heating it but that didnt work either [:@]
Old 06-21-2011, 05:10 PM
monjet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Easy trick
Get a small pointy pliers and insert the point inside the tubing and open the pliers a little bit, insert deeper the tubing and open them again,
when you think you got enough tubing inside the pliers take the tubing out and go for the filter
Hope this helps, sorry for the spanglish
Juan
monjet is offline
Old 06-22-2011, 02:28 PM
FenderBean
FenderBean's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks aftr both thumbs ending up with blisters from pushing so much I finally got it.
