Jet Central Turbines - Artes Jet Jet Central Turbines formerly the Artes Jet forum
Throttle learning question
Reply
Old 09-18-2011, 07:10 PM
FenderBean
FenderBean's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Throttle learning question
Hi everyone just a simple question the first couple of time I have ran my rhino I didnt get the chance to do the throttle channel memorize like the books states. is it to late to do this or does the ECU know when you slowly go full throttle the slowly decreasing, stopping at each percent with a pause that you are doing this.
FenderBean is online now
Old 09-18-2011, 07:37 PM
BluFox
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Throttle learning question
Fenderbean:
Your Rhino may or may not need to go through the "throttle learning." The ECU software version will let me know if this is necessary. Software version can be found by menu up to the second screen which shows battery V, pulse and % of throttle trim and stick as well as V of software.
Software versions change often resulting in possible errors in the manual.
For training purposes, simply start, let sit at idle, the go to full throttle. Wait at full throttle until rpm reaches max and PW stabilizes. THEN and only then, reduce throttle one click at a time pausing 5-10 seconds at each interval until arriving at idle. You have now completed the learning process.
For quicker response to your questions, please email me @ jetartessale@aol.com I only check RCU 3 times a week.
Best regards,
Eric
BluFox is offline
