Jet Central Turbines - Artes Jet Jet Central Turbines formerly the Artes Jet forum
Jet Central Eagle!!
Reply
Old 09-26-2011, 09:58 AM
Diego Doctor
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Jet Central Eagle!!
Hi guys I´m needing some help,
Has anyone have the parameters for the Eagle? I have one that´s no longer on warranty, and I´m using the Xicoy ECU.
I need this informations:
1-)On the RUN Menu: a) Full power speed
b) Idle speed
c) Stop speed
d) Aceleration delay
e) Decelarion delay
f) Stability delay
2-) On the Start Menu: a) Starter power at ignition
b) Ignition Max RPM
c) Ignition Min RPM
d) Pre Heat Time
e) Starter power at Preheat
f)RPM 100% starter
g)Rpm off starter
h) Rpm to reconnect starter
Any information will be welcome!!!
Thank you everyone!!!!!!!!
Diego Doctor is offline
Old 09-26-2011, 12:11 PM
jetmon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Jet Central Eagle!!
Hello Diego Doctor
Some parameters change depending on ECU software version, you can check it going to the second screen on the lower right
Please let me know so I can send you the parameters
Regards
jetmon is offline
Old 09-27-2011, 03:38 PM
Diego Doctor
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Juan!!!!
I´m sorry about the delay, my ECU version is the V.5.63, is the gold ecu from xicoy by Gaspar Espiell.
Thank you a lot, you save me!!!!
Best Regards!!!!
Old 09-27-2011, 03:56 PM
jetmon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK, here is what we are using, probably you need to fine tunning them:
1-)On the RUN Menu: a) Full power speed 128.000
b) Idle speed 32.000
c) Stop speed 20.000
d) Aceleration delay 15
e) Decelarion delay 15
f) Stability delay 50
You may need also the "pump limit" 700, this one may need adjustment, set it at +100 of your PW reading when you are at full throttle
b) Ignition Max RPM 4000
c) Ignition Min RPM 2000
d) Pre Heat Time 8
e) Starter power at Preheat 95
f)RPM 100% starter 40.000
g)Rpm off starter 25.000
h) Rpm to reconnect starter 20.000
You may also need the "Starter power at ignition" 85
Regards
jetmon is offline
Old 09-27-2011, 04:13 PM
Diego Doctor
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you Juan!!!!
I will fly this weekend and try this parameters!!!!
Best Regards
Diego Marques!!!
Old 11-17-2011, 11:01 AM
Diego Doctor
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Juan!!
I already had 15 flights with my Eagle on a Ultra Flash, I´m having some problem with the fuel ramp it´s takens to much, How I can get it faster?
Best Regards
Diego Marques.
