Jet Central Turbines - Artes Jet Jet Central Turbines formerly the Artes Jet forum
Diesel
Reply
Old 11-05-2011, 04:55 PM
rcguy59
My Feedback: (8)
rcguy59's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Diesel
In the announcement of the latest version of the Rabbit, diesel fuel is listed as a fuel option. What is JetCentral's position regarding the use of diesel in the older engines as far as running and warranty are concerned. Thanks in advance.
rcguy59 is offline
Old 11-05-2011, 06:36 PM
furycham
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Diesel
As far as I know, and from a spanish forum you can use diesel in:
Rabbit: all
Cheetah: all
Mammoth: all
Rhino: Only Kerostart
Falcon, Eagle and bee is not recommended.
Use only 100% synthetic oil with "JASO FC" specs like Motul 710 or Red Line Racing. 50:1 or 2% only, no more, no less.
I am running Diesel in my Cheetah and no problems so far.
Hope this help.
furycham is offline
Old 11-05-2011, 07:10 PM
rcguy59
My Feedback: (8)
rcguy59's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Diesel
Sounds great, But I'd sure like to hear from Eric or the factory before I change my Rabbit's diet. Sounds like my Bee will have to stay with kero, though. Must be the tiny injector needles.
rcguy59 is offline
Old 11-06-2011, 06:51 AM
BluFox
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Diesel
rcguy59:
Yes, Diesel (low sulphur) is approved for use in the turbines as stated by furycham. I have been using Diesel since July in My Rabbit 100 prototype with no issues.
We highly recommend the use of synthetic with the rating stated by furycham. Amsoil Dominator is the brand and specific product I am using. Being red in color is a benefit as it turns the fuel red. . .never a mystery as to "if" you put oil in the fuel. Mix ratio is 2.5% which is 1/2 quart. Any other synthetic with "JASO FC" specs is approved as well. Insure you have the correct mix ratio of 2.5%. Our Turbo Prop system requires the use of synthetic to maintain the Lifetime Warranty. The jf50Bee II KS (kero start) turbine may use Diesel as well, but performs better with Jet A or packaged (clean) kerosene.
I will be posting officially our findings and recommendations on RCU shortly. BTW, we have been testing Diesel in Europe for over a year and here in the US since July. Only discernable difference is a plume of smoke immediately after shut down prior to auto cool engaging. . .
Kind regards to all. . .
Eric and the Jet Central team
BluFox is offline
Old 11-06-2011, 10:22 AM
rcguy59
My Feedback: (8)
rcguy59's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Diesel
Thanks, Eric. Low sulphur is all that's available around here, anyway. I'll mix a batch for my Rabbit and give it a try. Mike
rcguy59 is offline
Old 11-10-2011, 01:15 PM
jetsett
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Diesel
Is this the oil??
http://www.amsoil.com/storefront/tdr.aspx
ID:	1684816   Click image for larger version
ID:	1684817   Click image for larger version
jetsett is offline
Old 11-10-2011, 02:49 PM
sailing1
My Feedback: (134)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Diesel
Hey Eric. Didn't see Mobil DTE light mentioned. Is that oil OK to use with Deisel in my Cheetah and Rabbit?
sailing1 is offline
Old 11-10-2011, 06:05 PM
rcguy59
My Feedback: (8)
rcguy59's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Diesel
That's the stuff. I'm going to use Stihl HP Ultra. It meets the same spec. and is also what I run in my gassers. About the same price as the Amsoil.
rcguy59 is offline
Old 11-11-2011, 04:37 AM
BluFox
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Diesel
jetsett: Yes, Amsoil Dominator is the correct or recommended product. Mix 2.5% or 1/2 quart per 5 gallons.
Sailing1: Mobil DTE lite is approved, but you must use 5% or 1 quart to 5 gallons for proper lubrication
rcguy59: Will work fine, but Dominator turns the fuel a nice red color. . .a good check to see if you put oil in your fuel ! ! !
Regards,
Eric
BluFox is offline
Old 11-11-2011, 01:07 PM
757Driver
My Feedback: (90)
757Driver's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Diesel
So I just want to be clear....I Cannot run Diesel in my Propane Start Rhino's that just came back? They eat the most except for the Mammouth. If that is the case, what makes the diesel unsuitable?
757Driver is offline
Old 11-11-2011, 04:51 PM
rcguy59
My Feedback: (8)
rcguy59's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Diesel
Thanks, Eric. I really appreciate straight answers and yours always are. My Bee is going in for service next month. Talk to you then. Mike
rcguy59 is offline
Old 02-09-2012, 06:25 PM
john491
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Diesel
If DTE Lite is used in Deisel a mix of 5% is required? Is 5% also required if using Jet A or kerosene?
John
john491 is offline
Old 02-09-2012, 06:29 PM
john491
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Diesel
If DTE Lite is used in deisel 5% is required? Is 5% required with Jet A or kero?
John
john491 is offline
Old 02-09-2012, 06:57 PM
monjet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Diesel
ORIGINAL: 757Driver
Hello 757Driver
Some propane Rhinos can work with diesel, please give Eric serial numbers to confirm
Diesel has more calorific power (I'm not sure if that was the right translation) than Kero, in other words, it burns hotter, and some combustion chamber parts can be afected
The Bee II is also aproved for Diesel
Sorry for the bad English
monjet is offline
Old 02-09-2012, 07:00 PM
monjet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Diesel
ORIGINAL: john491
John
Regardless the fuel you are using the recommended ratios are:
DTE lite 5%
Turbine Oil 2.5% to 5%
2 Strokes oil 2% to 2.5%
Regards
Juan
monjet is offline
Old 02-11-2012, 10:53 AM
757Driver
My Feedback: (90)
757Driver's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Diesel
Gracias!
