Jet Central Turbines - Artes Jet Jet Central Turbines formerly the Artes Jet forum
RHINO fLAME OUT
Reply
Old 11-06-2011, 02:02 PM
BillJ
My Feedback: (19)
BillJ's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RHINO fLAME OUT
Have just bought a plane with a Rhino... Have no problem with starts... but engine will flame out (with smoke) taxiing out....Can find no air leaks at uat and actually we set the plane on a test stand and ran it at various throttle settings for 4 + MINS...SHAKING THE CRAP OUT OF IT...still ran great... Put the plane on the ground and taxi out (grass runway) and it flames out in about 45 seconds...
Going to change the fuel line between turbine and cut off valve.
Does anyone have a thought ?... All lines are wired..See nothing but fuel in lines up front . Changed the Throttle curve settings... Reload transmitter several times... Flames out reading 17000rpm 434 degrees C....
BillJ is offline
Old 11-07-2011, 03:05 PM
BluFox
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: RHINO fLAME OUT
Bill J:
Charley is waiting for your call so the two of you can get together. . .I will stand by for any parts which may be needed
Regards,
Eric
BluFox is offline
Old 11-09-2011, 04:24 AM
BillJ
My Feedback: (19)
BillJ's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Don't ask me what we did except venting each tank individually.... Ran like a charm yesterday... Wish we had some pics of Charlie chasing me around the sky with his Eurosport... Almost had a couple of Blue Angel moments... Although Charlie kept smokin me down the front straight... I told him if he kept that up I'd have to wedge a bigger engine in.......LOL
Thanks Eric
BillJ is offline
Old 11-09-2011, 06:14 PM
FenderBean
FenderBean's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Have you tried range checking maybe a signal problem?
FenderBean is online now
Old 11-09-2011, 07:27 PM
BluFox
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good thinking. . .however, if a range issue (loss of signal) the error code will be" Rx signal lost or Fail Safe." Such was not the case with this turbine.
Two heads are better than one which seems to have sorted out the issue.
Regards,
Eric
BluFox is offline
