Jet Central Turbines - Artes Jet Jet Central Turbines formerly the Artes Jet forum
high idle/flame out
Reply
Old 11-07-2011, 12:05 PM
jetsett
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default high idle/flame out
Gotta say first..I love my JC BEE II KS. Since June, I've logged over 120 flights, and over 20 hours. Not a single problem.
I noticed the last few flights, that the idle seemed high, around 60k or so. Last flight went well. Landed and while spooling up after stopping, at about 70% throttle, the engine quit. (No smoke)......Last shutdown reason on the ECU.....SPEED LOW.
I went through and checked all the transmitter and ICS setting and reprogrammed the ICS to learn the transmitter.
Started the turbine. idled fine at 55k. Did the ecu learning procedure. Back down to idle......85,000. Wouldn't come down.
Any ideas??
Don
jetsett is offline
Old 11-07-2011, 03:16 PM
BluFox
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: high idle/flame out
Don:
Couple of things. . .have you changed fuel lately, ECU battery fully charged and most importantly, have you been tracking the PW (pulse width ) of the fuel pump during operation. If PW is registering higher, you may have a fuel issue within the system. Can you check the delivery of the fuel pump? I would like to know how many ounces it is delivering in 5 seconds. Other than the obvious such as possible filter contamination, check the system. If possible, hook up an alternate source such as your taxi/over flow tank direct to the fuel pump and check results.
Let us know.
Eric
BluFox is offline
Old 11-08-2011, 10:32 AM
jetsett
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for your quick reply. I will troubleshoot today and report back.
How would you like to check my delivery for thefuel pump?? .....Prime on full for 5 seconds? or for 5 seconds from the time i push the prime button>
Don
jetsett is offline
Old 11-08-2011, 12:03 PM
BluFox
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Don:
If possible, hook up a fresh "D" cell battery for the test.
I have requested a new fuel pump be sent to you. . .please check your email for my follow up .
Regards,
Eric
BluFox is offline
Old 12-02-2011, 08:48 AM
jetsett
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Replacement pump has solved this issue. The bee is idling fine now. Thanks Eric/Jet Central!! excellent service!!
jetsett is offline
Old 01-10-2012, 11:38 AM
jetsett
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I can't reiterate enough, what great service I've received from Eric and Jet Central. BAR NONE.
Please do not hesitate to pass up the chance to own one!! Jet Central forever!
jetsett is offline
