Jet Central Turbines - Artes Jet Jet Central Turbines formerly the Artes Jet forum
High voltage
Reply
Old 11-26-2011, 10:06 PM
rcguy59
My Feedback: (8)
rcguy59's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default High voltage
I want to use all "high-voltage" servos on my current turbine project. This will mean a 2S LiPo RX battery. Since the ECU sees RX battery voltage, my question is this: Can the ECU tolerate 2S LiPo voltage (unregulated) coming from the RX, or do I need a regulator between the RX and the ECU? I have the AU-605 ECU and the turbine is a SuperBee. Thanks.
rcguy59 is offline
Old 11-27-2011, 07:19 AM
BluFox
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: High voltage
rcguy59
I suggest using 2s2p configuration to insure redundancy although 2s is perfectly OK. . I would purchase at least 3000 mAh with a 25c rating. As for the Rx to ECU. You must check with the brand radio manufacturer to determine if you must regulate the V to the Rx. Voltage out from Rx to ECU will not be an issue. No nead to regulate ECU battery if using 2s2p configured batteries.
Regards,
Eric
BluFox is offline
Old 11-27-2011, 12:50 PM
rcguy59
My Feedback: (8)
rcguy59's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks, Eric.
rcguy59 is offline
Old 11-29-2011, 11:45 AM
gunradd
My Feedback: (9)
gunradd's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That is a relief. I am putting all HV servos in my new plane and had the same question.
gunradd is offline
