Jet Central Turbines - Artes Jet Jet Central Turbines formerly the Artes Jet forum
Spacing b\w nozzle and tailpipe.
Reply
Old 08-20-2012, 12:37 AM
macmuz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Spacing b\w nozzle and tailpipe.
Hi guys, gonna ask the same question again as my previous post - Spacing between turbine nozzle and tailpipe? - 5/6/2012 11:06 AM.
In my previous post, phjoker listed a pdf from rcisfun and I thank u for that..
looking into the pdf, it shows to measure from the end of the turbine nozzle and a tailpipe.
well now i have put a bell mouth and want to know where to measue from now?
Do i measure from the start of the inside of the radius or outside of bellmouth to turbine nozzel?
Geez, i'm really confussed on this!
I've put some pics and the pdf for you to see.
Thanks Mario.
ID:	1793466   Click image for larger version
File Type: pdf
macmuz is offline
Old 08-20-2012, 03:55 AM
rcjetsaok
My Feedback: (7)
rcjetsaok's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Spacing b\w nozzle and tailpipe.
All my pipes are bell mouthed and non bypassed and the measurement is 1 1/2 inch as recommended.
Dan
rcjetsaok is offline
Old 08-20-2012, 12:59 PM
Sparhawk
Sparhawk's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That seems a little much. The gap on mine is 3/4" from end of turbine exhaust to start of bell mouth.
Dan
Sparhawk is offline
Old 08-20-2012, 04:47 PM
smitty1001
My Feedback: (29)
smitty1001's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Depends on the engine. Danno runs the big blocks.
Engine a super bee?
smitty1001 is offline
Old 08-20-2012, 10:58 PM
macmuz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi there.
The engine is a Rhino.
Seems to be a bit of a difference between sugestions.
Anyone form JC willing to chime in?
Thanks Mario.
macmuz is offline
Old 08-21-2012, 09:50 AM
Sparhawk
Sparhawk's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The gap I have for my Merlin 160 is 1"
Dan
Sparhawk is offline
Old 08-21-2012, 10:53 AM
BluFox
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
macmuz:
Please refer to and adhere to the chart as supplied by Jet Central. The correct distance from the end of the nozzle of the turbine to the edge of the knurled front part of the pipe is 1 1/2 " for the Rhino. This is the maximum setting which produces the most thrust / cooling for the pipe. Also refer to the chart or previous received pdf file for the correct pipe ID to be used. Extensive testing has been done to chart these numbers. OH, pipe is required to be centered to the turbine nozzle as well. Any questions, please email to : jetartessales@aol.com
Regards,
Eric
BluFox is offline
Old 08-21-2012, 08:17 PM
macmuz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Guys,
thanks for the replies.
I must have missed it in the manual.
Must go over it again.
Once again, thanks.
Mario.
macmuz is offline
Old 01-29-2013, 05:58 AM
andywynn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi blufox,
I am just setting up my Jet Central rhino and you mention 1.5" (37mm) as the distance from the tail cone to the start of the pipe, in the manual it says a maximum of 32mm (1.25") My tail pipe is 80mm diameter and is currently set to 1.5" (37mm) is this ok or shall i reduce it to 32mm.
Thanks in advance
Andy
andywynn is offline
Old 01-29-2013, 07:21 AM
andywynn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Would just like to thank Blufox for his excellent e-mail service to my question. Answer is i can use either so i'm good to go.
Once again thanks
Andy
andywynn is offline
