Jet Central Turbines - Artes Jet Jet Central Turbines formerly the Artes Jet forum
Cheetahs
Reply
Old 06-15-2013, 12:23 PM
snobird
My Feedback: (35)
snobird's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Cheetahs
Have cheetahs in my SM a-10. One starts right off ,no issues, the other one stars very hard , will get ignition failures over and over until it finally will start, last start took 12 try's . After start it runs as it should . ?????
snobird is offline
Old 06-17-2013, 07:24 AM
BluFox
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Cheetahs
snobird:
Two things to check;
1. did you rotate the turbine in the mounts so the name Cheetah is on top. . .that is facing upward toward the top of the nacelle? Please do so if not already accomplished.
2. "Ignition fail" is just that. . .failed to get ignition. The manual describes the parameter to be adjusted if you get failed ignition. Also, please check both the 3mm and 4mm lines from your fuel source to the turbine for any restrictions.
Thanks for the question
Eric
BluFox is offline
Old 06-17-2013, 10:50 AM
snobird
My Feedback: (35)
snobird's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks. Eric .both turbines have the name on their side. ill change. this is news to me. name facing up..thanks
snobird is offline
