Jet Central Turbines - Artes Jet Jet Central Turbines formerly the Artes Jet forum
Falcon Shutdown with Thermocouple reading Zero
Reply
Old 06-15-2013, 05:33 PM
BCoston
My Feedback: (7)
BCoston's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Falcon Shutdown with Thermocouple reading Zero
Eric,
My Falcon that just returned from service in Mexico shut down on it 3rd flight due to temp reading of zero. Also on the 2 flights prior to that the turbine had a strange sound when throttled up from idle. It sounded like a jake brake on an 18 wheeler and sounded as if it were getting to much fuel. Please advise on what I need to do.
Brian
BCoston is offline
Old 06-17-2013, 07:30 AM
BluFox
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Falcon Shutdown with Thermocouple reading Zero
Brian:
Please check the connections for both the thermocouple and the RPM sensor. Sudden loss of temperature is usually the connection or the extension being used. I suggest change out of extension being used (maintain polarity) then check for temp reading by using the HDT. Turbine does not have to be running to do this.
The rumbling you hear while acceptable, may be enhanced by the acceleration delay being set to aggressive. Try a smooth, slow transition from idle to 1/2, then 3/4 then full throttle.
Please update us with your findings.
Regards,
Eric
BluFox is offline
Old 06-17-2013, 08:16 AM
Sparhawk
Sparhawk's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My Falcon makes the same "growl" and runs great. I think this is very normal for the Falcon, and I wouldn't worry about it.
Dan
Sparhawk is offline
Old 06-17-2013, 03:08 PM
BCoston
My Feedback: (7)
BCoston's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Connected the rpm sensor and the thermocouple directly to the ecu and temp is still reading "000".
BCoston is offline
Old 07-04-2013, 05:52 PM
cmte_wandermiguel
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: BCoston
Eric,
Brian
I'm having the same problem, I've done several tests.
cmte_wandermiguel is offline
