ICS numbers?
ICS numbers?
Eric,
I purchased a USB cable so that I cold look at the data in the ICS. I understand , Cycle, temp, RPM in the text file but am not such about page, aux , throttle, and pump numbers. Can you shed any light on these four readings. The graphs and numbers are very interesting.
Glenn
Glenn
My Feedback: (10)
FL
RE: ICS numbers?
Glen:
Data is collected in 1/2 second intervals saving the last 51 minutes of record.
PW= pulse width of fuel pump during operation. This of this as a % of total voltage available to the pump. Pump limit is pre set at our manufacturing facility. . .normally 800. Recommendation is that you record pw readings showing average at idle, half and full throttle. These records then become the base line for future comparison
Send me your email address so I can send a chart of definitions .
Regards,
Eric
Regards,
Eric
My Feedback: (7)
RE: ICS numbers?
ORIGINAL: Edgar Perez
[link=http://dreamworksrc.com/catalog/fadec-interface-cable-p-247.html]All in one place[/link]
Edgar's link is good. However, If you have the newer ICS with the Servo type connector, that cable on the link will not work. It is for the original ICS's. Contact Eric for the newer cable.
Danno
My Feedback: (10)
FL
RE: ICS numbers?
Glen:
The interface usb cableis in stock. We now have two. The one you will need is the unit with usb on one end, phone jack on the other. They are $35USD plus $15 shipping to your postal code.
Software may be downloaded from Gaspar's web site www.Xicoy.com
I return to the office on Monday after 12noon
Regards,
Eric
Regards,
Eric
My Feedback: (13)
RE: ICS numbers?
Bob,
What windows version are you using?
Never had that message before..
Are you getting a "connection OK" message? I guess it can't write to the disk... can you install as administrator?
some comments about the program (you can use search in RCU jets forum):
-if you dont follow his instructions for downloading the right driver for the usb cable ,it will never work.
-you have to plug in the cable in the computer ,or laptop like me , and in the ecu before you start your computer , else the connection will not work.
