Jet Central Turbines - Artes Jet Jet Central Turbines formerly the Artes Jet forum
Cheetahs
Reply
Old 09-03-2013, 08:08 AM
snobird
My Feedback: (35)
snobird's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Cheetahs
Eric, can I use the fuel valve in place of the Kero valve, are they the same ( I just received three fuel vales and no Kero start valve
snobird is offline
Old 09-03-2013, 08:39 AM
zonker123
My Feedback: (21)
zonker123's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm not Eric but I've interchanged them with no problem You do have to step the the output side of the solenoid from a 4mm to 3 mm because the kerostart input at the motor is 3mm. Step it down as close to the solenoid as u can. I would also make sure to relabel the solenoid so as not to confuse them when hooking them up to the ECU. Don't ask how I learned that
Good luck and enjoy your Cheeta, mine has been nothing but a pleasure.
Mike
zonker123 is offline
Old 09-04-2013, 08:56 AM
BluFox
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
David:
Valves ordered were the valves shipped. Yes, as my dear friend Zonker said, you can use the F valve for the K valve. Label to keep yourself out of difficulty. Second, carefully remove the 3mm FESTO from the suspect defect K valve replacing the out (exit) 4mm FESTO on the F valve. CAUTION. . .if you over tighten, the threaded body may or can break off. Also, check for the washer for each FESTO removed and re installed.
Eric
BluFox is offline
