Jet Central Turbines - Artes Jet Jet Central Turbines formerly the Artes Jet forum
Bleed air?
Reply
Old 10-15-2013, 04:14 PM
jkpape
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Bleed air?
Has anyone tried pulling bleed air from an R/C turbine (like full scale turbines) to maintain air pressure in the air tanks used for retracts? I think would be a winner if it could be done without adding a huge cost increase.
jkpape is offline
Old 10-15-2013, 05:20 PM
BluFox
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
At this time, we have not. Perhaps you should post this question as a new thread for the general populous of the RCU jet community .
thanks for the question. . .
BluFox is offline
Old 10-23-2013, 09:14 PM
Dreddi
Dreddi's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have looked into it but apparently at full power youre only talking around 30 psi. People used to pressurize smoke tanks with it. The amount of volume youre talking about is such a small percentage of the total mass flow that the engine wouldn't even notice.
Dreddi is offline
Old 10-24-2013, 06:43 AM
Dr Honda
Dr Honda's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I played with it a little with an air start AMT. (the start line, has pressure on it, while running) At full power, it would make around 24~25 PSI. (This is on a AT180) It's really not enough pressure, if there is a leak, and something is stuck. BUT... on the bigger engines... the more pressure you make internal. SO... on a 40 Lb thrust engine... you may have 50~60 psi in the case.
Dr Honda is offline
