Jet Central Turbines - Artes Jet Jet Central Turbines formerly the Artes Jet forum
Flames on landing.
Reply
Old 01-11-2015, 01:20 AM
Hertzinator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Flames on landing.
Loving the Rabbit in my Piroti Rebel. However have now on 2 occasions after a issue free flight had a large flame, (2 feet ) on trying to power up on final approach or just after landing on taxi. A restart poses no issues afterwards. The one thing that I have noticed is that the small plastic cap on the starter motor is loose and hangs out a bit. it will push back in and stay there but is loose. Could this be the cause of the flame issue?
From what I see that cap should retain the shaft of the motor Is this correct?
Hertzinator is offline
Old 01-11-2015, 08:38 AM
BluFox
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
First, it sounds like the acceleration delay is set too aggressive (fast) and as a result, the turbine cannot respond fast enough. Go to the RUN menu, then to "accel delay" and check setting. Note this prior to changes. If setting is Fast or Very Fast, reduce (data down) one setting. This is for all PowerPack versions of the Rabbit and Rabbit SP. If it is not a PP version, acceleration delay will be numerical. Again, note the setting and INCREASE the number (ie; 12 increase to 16 ) and try again.
Small black cap is a filler type gromet. It does not hold the starter shaft in place. So, nothing to worry about here. Just press it back in . . .
Cheers,
Eric
BluFox is offline
Old 01-11-2015, 09:29 PM
Hertzinator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Eric,
Ok so if the motor is loose inside the housing the problem would be ?
Is it possible that the with the motor being loose inside the housing that it may be causing some friction on the turbine, enough to prevent it from spooling up according to the fuel that the ecu is delivering, that it would cause the flame ?
Old 01-12-2015, 07:37 AM
BluFox
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No, once the start sequence is complete and the turbine is at idle running Ok, the starter motor has disengaged ( separate from Compressor nut) and free from turbine. The starter motor will not re engage until the cool down cycle is beginning.
Eric
BluFox is offline
Old 01-13-2015, 04:45 AM
Hertzinator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok so what I can't explain is why the starter motor will not engage unless I am holding the cap in ? with the cap out the motor is moving around inside the housing .?
Old 01-14-2015, 12:00 PM
BluFox
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Please send a picture or short video of what you are explaining with the starter,
Eric
BluFox is offline
Old 01-15-2015, 12:29 AM
Hertzinator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Eric will send to Email jetartessales@aol.com
Old 01-18-2015, 03:20 AM
Hertzinator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Eric,
What i can't understand is why after approximately 40 flights why this flame on landing has only developed now on he last 2 flights.. The delay setting has not been changed since the first flight. ????? I hope you received the email I sent ok.
