Battery Overvoltage
My Feedback: (57)
Battery Overvoltage
0.9V,
I have taken my VT90 out of storage after more than a year. Lubed it, set it up and attempted a bench run.
I am using the A123 LiFe battery provided by Jet Central, same one I was using prior to storage.
During startup I kept getting battery overvoltage, which was odd because on the ECU Pb=9.9-10V. The battery seemed fine. I discharged the battery for an hour, and the ECU was reading Pb=9.8V and it would not fire up. Same overvoltage message.
So I tried a 7.4V Lipo from another engine and it worked good. Engine ran fine.
Is there an adjustable ECU battery voltage parameter I can adjust or is there something else hosed up?
David
David
My Feedback: (10)
FL
David:
The 9.9LIFe battery requires the V10 ECU. You did not say which ECU you have. In the START menu, there is a parameter for setting igniter voltage (Glow Plug) and low battery voltage. Additionally, you must SET in the START menu the type battery you are using. If not set correctly, you will experience a repeat of your last experience.
Regards,
Eric
Regards,
Eric
Hola David
I see the problem now, looking at your HDT I see that your ECU is aluminum case and they does ones can not handle 9.9V
Please tell me your serial number to see why we didn't replaced it
Sorry for the trouble
My Feedback: (57)
Juan, I dug through my old email and found some history.
I purchased this battery from you a couple of services ago, and I was sent the wrong one. I was supposed to send it back for replacement but it seems I just purchased another one locally and never actually returned it. That's why I have a Jet Central 9.9V battery!
I am glad because I was really wondering what could have happened, as the engine runs fine on 7.4V.
thanks, and sorry for the confusion!
David
David
My Feedback: (21)
FL
David
David
great im happy you were able to figure it out. Please feel free to give me a call if needed.
321-412-3078
